Salsa Selma- Mtbr.com
Results 1 to 5 of 5
Thread: Salsa Selma
    Salsa Selma
    Are people getting these in around 20 lbs or so with a reasonable build?
    Reputation: Flat Ark's Avatar
    I had a Mamasita set up SS and it came to around 18.5 pounds. Same frame minus the EBB but I did have the added weight of a tensioner. I guess it depends on what you call reasonable but maybe this will give you an idea.
    Mamasita frame
    White Bros. carbon fork
    American Classic Wheels
    Truvativ Noir crank
    Race Face carbon post
    Salsa carbon bar
    Small Block 8/Weirwolf 2.55
    XT pedals
    The Tyranical Teabagger
    Reputation: cyrjm's Avatar
    Mine weighs 23lbs with a Cannondale Lefty. I could have got it sub 20 but I didn't want to spend a TON of money. That's also with tubes...I'll run it tubeless the beginning of next season. My chain weighs a ton too...I went for style points instead of LB's.
    *not pictured with my brakes installed
    I like bikes.
    2012 Transition TransAm 29er
    2010 Rigid Salsa Selma SS
    2015 Transition Smuggler
    2015 Cannondale Scalpel
    Reputation: CoffeeBean's Avatar
    got mine @ 19.5 lbs right now. with rigid carbon fork....
    Monkeylite Bars
    Thomson Stem
    Exotic CArbon fork w/Carbon steerer.
    Stans Arch wheels w/AC hubs
    Nanoraptors
    flite saddle
    easton carbon seatpost
    magura brakes
    stylo cranks
    eggbeater pedals
    Be Who You Are and Say What You Feel Because Those Who Mind Don't Matter and Those Who Matter Don't Mind...Dr Seuss.
    SS or Die
    Reputation: -Muz R-'s Avatar
    Had my Mamasita at 18.5lbs without going silly.
    Medium Mama frame
    Exotic Carbon fork w/ carbon steerer
    CK headset
    XTR BB
    Xlite Ti skewers
    Yess BB chain tensioner 100g
    I9 wheels
    KMC HX Z610 Chain 325g
    Surly 20T cog
    Blackspire Velomono 32T ring
    M960 cranks cut and polished
    Egg beater pedals Ti w/ Wade Industries Ti Spindle
    Groovy Cycles Steel Luv Handle bar
    Ritchey WCS post Carbon
    SLR saddle w/ Ti rails
    Ritchey WCS stem V4
    Ignitor front, Kenda Karma rear tires
    Marta Sll Brakes with Ashima Airotors 160mm
    Could go lighter without threatening durability I feel.
    "Be the Gear..."
