?'s about an ENO DisC- Mtbr.com
Results 1 to 9 of 9
    Wandering not Lost
    Reputation: BThor's Avatar
    so if you do use an eno disc hub....does it cause problems w/ the rotor/pad interface...as in not contacting in the correct aera due to the arc of the axel...aw hell will this thing work ?
    Reputation: ernesto_from_Wisconsin's Avatar
    adapter
    Quote Originally Posted by BThor
    It comes with an adapter for the disc tabs, which is also eccentric to avoid problems. It works just like the standard eccentric. Once White Ind. sends me the images, I will put them in the site.
    Wandering not Lost
    thanks...please post pics for the 3d challenged...
    peace
    Thor
    or better yet I plan on converting a new 05' cannondale F1000
    http://www.cannondale.com/bikes/05/cusa/model-5FS1.html
    using the eno...disk in the rear...will it work?
    Appalachian Singletrack'n
    Reputation: Endomaniac's Avatar
    Will White's brake adapter work with all IS mount brakes or is it for post mount calipers only?
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    peace
    Thor
    Courtesy Hollywood:
    http://forums.mtbr.com/showpost.php?...63&postcount=3
    Good question about post and IS mounts though...
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Reputation: Nater's Avatar
    From what I can tell...
    The mounting holes that are on the eccentrics bolt to the IS mounts on the frame, and then a post mount caliper mounts to the other holes on the adapter. So I think it would only work with IS mount frames, but there aren't many post mount frames around any more?
    The Caliper mount pattern not the frame mount pattern.
    It looks to me like Whites adapter attaches to the frame’s IS mount and allows you to attach a post mount caliper (Hays, avid etc…) to the eccentric adapter. So If I currently have an IS mount caliper it will not work with this adapter. This is what I interpret from the couple of pictures I have seen but I could be missing something.
    -arschloch-
    Quote Originally Posted by Endomaniac
    yes, I concur from the pictures in Hollywood's thread, it does SEEM that way. guess we'll just have to wait til someone gets one and gives us a review.
    To air is human, to dig is divine.
    Hairshirt Rider
    Reputation: Loudpawlz's Avatar
    Um - go to the source
    Rampant speculation going on here
    Some of it sounds good, and most of it sound right, but if you really want to know, email White. I usually get same day response.
  1. ENO Eccentric Disc: When, where, how much?
    By chuffer in forum Singlespeed
    Last Post: 10-27-2004, 07:13 AM
  2. New ENO disc thingy question
    By jayoutside in forum Singlespeed
    Last Post: 10-18-2004, 06:57 AM
  3. Eccentric eno disc Q
    By jubilee in forum Singlespeed
    Last Post: 10-08-2004, 02:15 PM
  4. deore discs?
    By xisaacx in forum Brake Time
    Last Post: 07-06-2004, 03:44 PM
  5. disc rear eno?
    By boris the blade in forum Singlespeed
    Last Post: 05-18-2004, 09:27 PM
