Running a ramped/pinned ring up front okay?- Mtbr.com
Results 1 to 6 of 6
    NardoSS
    Guest
    Cambria Bike decided to take Wednesday late morning, Thursday, Friday, Sat, and Sunday off so my on line order hasn't moved past step one.
    Anyway, is it okay to run a standard geared style (ramped with pins) front 32 ring on my single speed until my Salsa ring arrives? Should it really matter other than looks if the tension is set correctly as it would be any other time?
    EBB and I run an 8 speed chain. I just don't want to miss a ride tomorrow.
    Side rant:
    Effing Cambriabike.com. Their one line store is NOT associated with the online store so it's just some nameless warehouse that doesn't care that I overpaid for two day air.
    Nov 2008
    It didn't bother me any.
    Reputation: asphaltdude's Avatar
    I used a pinned/ramped Truvativ ring for almost a year with no problems.
    Ride more!
    as long as your chainline is good you shouldnt have issues with the chain jumping off, but be aware that it could
    I ONLY make weird noises when i ride SS
    organically fed
    Reputation: w00t!'s Avatar
    Quote Originally Posted by NardoSS
    Side rant:
    I'm sorry you're having a bad day.
    If it helps, I'm still running the original ramped chainring and the original 9-speed cassette (ramped, obviously) with a tensioner and it's doin' just fine.
    NardoSS
    Guest
    Well, that's good enough for me. On it will go and thanks for the advice. It's good to know that I can just cancel my order.
