Rumble as SS (vert dropouts)- Mtbr.com
Results 1 to 2 of 2
    Reputation: xdefx's Avatar
    All...I picked up a 2004 Moutain Cycle Rumble. After I got it and had the HS cups pressed in, I decided to try and set it up as a SS (was originally going to do 1x9). Didn't know anything about the S/1, so I have the standard vert dropouts.
    Anyone setup one of these as SS? The one with the vert dropouts? Can I get lucky with a ring/cog combination, or will I need a tensioner no matter what? Manufacturer specs put the c/s at 406mm.
    Thanks in advance.....
    Reputation: gatman's Avatar
    Look under the FAQ on the right --->
    There is a link to some calculators that will help you out.
    You could always get a new rear hub
  1. Rumble as SS (vert dropouts)
    By xdefx in forum Downhill - Freeride
    Last Post: 03-18-2005, 06:03 PM
  2. for 05 - titus with ss dropouts
    By stick-in-the-mud in forum Singlespeed
    Last Post: 12-16-2004, 12:12 AM
  3. SS with vert drops?
    By diiulio in forum Singlespeed
    Last Post: 08-24-2004, 01:43 PM
  4. SS & geared dropouts
    By CBass in forum Singlespeed
    Last Post: 07-28-2004, 11:10 AM
  5. SS dropouts convert to 9 speed rear wheel?
    By aircrook in forum Singlespeed
    Last Post: 05-11-2004, 01:35 PM
