Rim brake pads- Mtbr.com
Results 1 to 10 of 10
Thread: Rim brake pads
    Jesus Freak
    Rim brake pads
    I run a mullet setup on my Soma; disk front-V back. I've used rim wrangler 2's, Some other Avid, and now some no name pads that I don't like.
    My wheel is a Mavic 317 on a WI eccentric non disk hub. Because of the hub I am trying to stick with the wheel I have rather than buying another wheel. My rim brake is a single digit 7.
    Does anyone have a good pad recommendation? Kool stops maybe? Which ones?
    is buachail foighneach me
    Reputation: sean salach's Avatar
    kool stop reds are great.
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    I've just switched to these Kool Stop Techtonics.
    They work well.
    Jesus Freak
    Quote Originally Posted by CB2
    They work well.
    Do you have to buy individual inserts or does the pad come with that setup?
    CB2
    CB2 is offline
    Jam Econo
    The pads come with the shoes and the shoe actually is part of the concentric setup for aligning you pads to increase stiffness.
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by Dave Moore
    I've tried a bunch. My favorites are Kool-Stop Salmon.
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Rusting Steel
    Reputation: Johnny5's Avatar
    +1 Kool-Stop Salmon with Avid SingleDigit 7 calipers and levers
    Jesus Freak
    Salmon's eh? I found two choices. One is the insert and the other has the threaded post(no cartridge shoe).
    I assume the insert would be the better choice?
    Tool
    Reputation: StageHand's Avatar
    I use cartridges because the pad changes are easier. I haven't noticed a performance difference between cartridges and non-cartridge. Check your brakes to make sure you have the shoes for cartridge pads, if that's what you want. You can get the shoes from Avid, Jagwire, Shimano, KoolStop and a few other companies.
    As for my pad preference, Avid black, closely followed by Kool Stop and Shimano black compounds.
    Kool-Stop Salmon inserts here too. I've found that I can set these up with no toe in. No squeal and I have really nice braking power. They are also easier on rims, it seems. I don't get what all the fuss is about discs. If I lived in OR and weighed 200 lbs. maybe I'd get it?
