Results 1 to 32 of 32
    Rigid forks - could you post your front air pressure
    Could you share your ideal front tire pressure that works for you in most conditions. I am new to my steel rigid fork and I like to learn from the pros "you". Thanks in advance.
    Reputation: OldHouseMan's Avatar
    I'd say just experiment; tire, rim, your weight and trail conditions play a lot in it.
    I guess I should at least tell you what I do...25 psi with tubes, Salsa Delgado rims and I'm 160 lbs.
    is buachail foighneach me
    Reputation: sean salach's Avatar
    35-45, conditions dependant, sometimes as low as the low twenties in the snow. this on a dual duty rim with tires ranging from 2.1 - 2.4+, tubes.
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    im about 200lbs, run seguaro tyres tubeless with 20-25lbs depending on where im riding. for most stuff 23 in the rear and 20 in the front.
    "Knowledge is good." ~ Emil Faber
    650b'sx2.3 tire @ 20-25 psi. It all depends on you're tire volume, rider weight, riding conditions, and all other kinds of crazy. Rule of thumb-how low can you go without pinch flatting or rolling a tire?
    i am 56kg...ride xc hardpack mostly....30psi on my 2.1 Kenda Small Block Eight. on the rear i run 38-40psi.
    FTM
    FTM is offline
    Reputation: FTM's Avatar
    Sep 2004
    ~20psi, Nevegal 2.3 run tubless in front, ~25psi Nevegal 2.1 run tubless in back. I'm 170lbs.
    HTFU and Ride
    Reputation: coachjon's Avatar
    A lot depends on rim size, tire width, tubed/tubeless, how tough the tire's sidewall is, the terrain and trail conditions you are riding on a given day, how big you are etc. I don't know if there is a standard you can use all the time.
    Reputation: disgustipated's Avatar
    I ride a 29er with alex adventurer rims (24mm wide) with mythos xc tires. My magical number is 40 psi.. i weigh 220lbs
    Calmer'n you are.
    28mm wide rim, Exiwolf tire, tubed, ~20psi, 190lbs rider.
    Quote Originally Posted by goldencalf
    *high-fives fellow reasonable air pressure buddy!
    Reputation: 3034's Avatar
    i weigh 210 lbs
    rocky terrain 28-30 lbs (dont want pinch flats)
    smoother terrain 24psi
    (slight return)
    Reputation: slide mon's Avatar
    28 lbs in exiwolf 29ers, 190 lb rider, steel fork.
    -slide
    Welcome to the Gem...
    Reputation: Mallanaga's Avatar
    i pinch flatted an exiwolf on a WTB double duty with about 40 psi... just throwing that out there.
    i'm getting some big apples soon. i'll be running prolly 35psi front and back.
    Ibis Tranny 29
    bhc
    bhc is offline
    Weirwolf 29er on Salsa Delgado rim
    21-22 psi
    No pinch flats yet
    Makes for a smooth ride on that rigid fork in the lower AZ desert
    Got Mojo?
    Reputation: BikeMojo's Avatar
    Jan 2005
    no quantifying
    You gotta factor in your weight, the rim, the tire you are running, with our without tubes, the day of the week, the elevation above sea level and the barometric pressure. Oh, and of course how smooth you are.
    After I am done with all that, my air pressure is just right to the squeeze... only takes a second, and requires no special equipment.
    aLaN AT BikeMojo DOT com
    |i|
    Reputation: robotkiller's Avatar
    Crossmax LUST 28-30 psi
    Reputation: AtotheZ's Avatar
    Nov 2007
    Tubeless, Exiwolfs, 210lbs I like to run the pressaure at either 27 or 28lbs. Oh and I keep a light grip on the bars in rougher sections, not light enough to get away from me but definitely no death grip.
    Redline Monocog 29er. I weight 168 after breakfast. Riding in Florida with sand and roots running my WTB Exiwolf 2.3 with 25 psi back and 20 front.300 miles no pinch flat.
    Birthday Collector
    Reputation: ATBScott's Avatar
    I run an Exiwolf in the rear, Resolution Pro in the front - both 29 x 2.3 tubeless (Stans). I run low-to-mid 20's in the front, about 3 lbs more in the rear. Never pinch flatted in a year and around 1800 miles, but did slice one sidewall open (Resolution Pro, rear) on a sharp rock, and also did have a front "catastrophically deflate" when it released the Stans under a heavy side-load. I was playing the "How-low-can-I-go?" game and only had about 17 - 18 psi in there. Too low for a rocky, rooty trail with cambered descents! 23 psi or so and everything is fine. I weigh 185 and generally do the "push on the top of the tire" test for presssure. Only know the psi because when I do pump them that is about what the guage shows where the "pressure feels right" to my push test. Play around and find what works for you. You can go sub-20 psi with tubes very safely on a larger tire, but watch for pinches with tubes!
    R.I.P. Corky 10/97-4/09
    Disclaimer: I sell and repair bikes for a living
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    mavic 717 rims....tubeless spesh' storm 1.8's....at 38 psi front and rear.....i'm 170lbs....i find they cut thru gunk easier and actually handle roots/rocks better than at lower pressures....weird huh?
    Click Here for Forum Rules
    Reputation: grrrah's Avatar
    Quote Originally Posted by CHUM
    Stan's Arch rims, usually run 36 psi. 200 lbs (210 riding) and dropping 38 for races usually.
    I thought I was the only higherish psi preferrer in the group. The other rigids in our group all seem to like the sub 30 ride.
    brg
    brg is offline
    Reputation: brg's Avatar
    Sep 2004
    i'm 106lbs and run 2.4 mutano raptors with 18psi.
    Reputation: serious's Avatar
    Jan 2005
    I am 160lbs and run 2.3 Hutchison Pythons with 25-26 PSI in the front and 2.0 Specialized Roll X Pro with 30 PSI in the back. This is on Bontrager Race Lite (TLR) wheels using tubes. I had no pich flats (or any flats) in the past 2 years of riding and racing.
    My rides:
    Lynskey Ti Pro29 SS
    RM Suzi Q 90 RSL
    KHS Team 29
    S-Works Roubaix
    KHS CX 550 cyclocross
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    caveat this with the fact that I have three separate gauges and they all read different pressures. One is 10psi high the other 10 psi lower than the first and the other is around 2/3 the first.
    Pressure is something best left to ball park and then refine using one gauge as a baseline.
    that said 200lbs-ish and 29er rampage 28-29psi.
    MTBR Posting Guidelines
    calories>electrons
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by mjaraica
    Depends on the tire. I use anywhere from <10psi (Gazzaloddi 3.0) to >40psi (Maxxis Medusa 1.55).
    mtbtires.com
    mostly hardpack, 30-32psi
    Reputation: mtbyker's Avatar
    Mar 2006
    Stans 355 29er rim, Specialized fast Track Pro, 22 or 23lbs around home (MI) and about 5 more in rocky terrain. I'm 175lbs and would call myself an aggressive rider. If I go less than than and come down a little crooked when bunny hoping or jumping I feel the tire want to roll sideways-weird feeling.......
    hardtails rule!!!
    I am new to this rigid deal and was wondering about pressures also. I weigh 156 on a good day, run a 2.5 tire up front, and recently ran 15psi with no problems.
    Reputation: tonyfromDC's Avatar
    20
    psi: 20
    weight: 155 lbs
    rim: cheap cr18
    tire: rampage
    tube: nasbar selfsealing
    no flats since I put it on...
    Reputation: Ze_Zaskar's Avatar
    180lbs, Hutchinson Phyton 2.0, 30psi, gym every day...
