Rigid fork problem, need advice.............- Mtbr.com
    Strongbow or Bust!!!!
    Reputation: The Tractor's Avatar
    I'm looking at getting a new fork and having it powder coated the same color as the Tractor, but here's my problem: The fork I have now is 430mm crown to axle. The Surly forks I am looking at will fit a 2.7 tire (the current fork I have is to narrow, a 2.5 rubs a bit). The Surly forks are the Instigator (447mm) and the 1x1 (413mm). Should I go with the longer one or the shorter one? The frame has a slack head-angle and I like how it rides, but I'm not sure how it will feel with a different length fork. Any advice?
    Rob
    Fermented Apple Juice rules!!!!!! BURRRRPP!!
    Reputation: shiggy's Avatar
    Dec 1998
    The Dimension disc only fork is ~415 mm and will take a 3" tire (gazzi 3.0) with a bit of side knob trimming.
    The the bigger/heavier tire I doubt you would notice much handling change.
    I think you would notice the slacker angles with the Inst. fork.
    mtbtires.com
    Where do you buy them?
    Hey Shiggy,
    Who sells the Dimension forks? I am going to try the WTB TimberWolf 2.7 race tires.
    Rob
    Cracker-magnon
    Reputation: gpsser's Avatar
    Webcyclery
    "Life is a [email protected]#^ing story problem, get used to it - my son.
  1. Help with Fork: Marzocchi Bomber Drop-Off Comp, 130mm travel
    By noah1711 in forum Shocks and Suspension
    Last Post: 05-11-2013, 05:28 AM
  2. Everything you need to know about the PIKE's Motion Control Damping!
    By MicroHuck in forum Shocks and Suspension
    Last Post: 02-21-2005, 10:25 AM
  3. Fork Oil Data
    By DGC in forum Shocks and Suspension
    Last Post: 12-31-2004, 08:13 PM
  4. Replies: 5
    Last Post: 04-14-2004, 08:19 AM
  5. rigid fork question: Alu, steel, carbon...
    By jh_on_the_cape in forum Singlespeed
    Last Post: 03-24-2004, 05:18 PM
