Rigid fork- Mtbr.com
Results 1 to 15 of 15
Thread: Rigid fork
    Nov 2007
    Rigid fork
    Salsa or Surly
    For a '95 Stumpjumper, repurposed as a beer/errand bike.
    Which would you use?
    The cheaper one.
    Reputation: rob_co2's Avatar
    Quote Originally Posted by p nut
    The cheaper one.
    Yep, save money on the fork and buy more/better beer.
    Reputation: smaxor's Avatar
    Dec 2004
    salsa
    Frt Range, CO
    Reputation: pursuiter's Avatar
    Be sure to pick the correct axle-to-crown length, the Surly 1x1 has two options:
    http://surlybikes.com/parts/1x1_fork/
    one chain loop
    Reputation: fishcreek's Avatar
    tange
    everything sucks but my vacuum cleaner.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Man, grab a cheap aluminum fork off the bay. Lighter and you're on streets anyhow.
    Low Rep Count
    Reputation: 1SPD's Avatar
    For real! What ever is cheapest for you in this case. Spend left over funding on more beer.
    SSolo, on your left!
    Quote Originally Posted by smaxor
    salsa
    Why?
    Quote Originally Posted by umarth
    Noooo
    Get off the couch and ride! :)
    Quote Originally Posted by Natedogz
    Noooo
    What the problem is? He's using the bike as an in-town beater. Any fork that will physically mount up should suffice. AC length, rake---who cares?
    $50 Dimension fork off FeeBay or Amazon. Call it a life.
    FWIW, I have a Surly 1X1 so I can get a fat tire on there if I wanted to.
    Frt Range, CO
    Quote Originally Posted by Dion
    $50 Dimension fork off FeeBay or Amazon. Call it a life....
    Dimension fork isn't suspension corrected, a suspension corrected 1x1 Surly fork costs ~$60....
    Dec 2010
    You guys just missed out. Soul Cycles had a clearance sale (ended about 2 weeks ago) and I picked up a suspension corrected fork for 9 bucks (msrp $65). They had 26" and 29" 4130 chromoly. Light and stiff. Here is a pic...
    That's the best picture I have right now.
    Reputation: dixie whiskey's Avatar
    If it's a beer/errand bike why opt to spend extra cashola on the Salsa? I don't understand the logic of choice. umarth nailed it.
    Listen! I would choose fat
    A rigid fork is light if it is not insane. I would choose a fork that is compatible with the fattest tires because that is the only way to get some suspension when needed. A rigid fork and the Endomorph tire, for example.
