Rigid + Alt BarSS- Mtbr.com
Results 1 to 82 of 82
    one chain loop
    Reputation: fishcreek's Avatar
    Rigid + Alt BarSS
    I am looking for inspiration and would love to try alt bars. Stem length and angle info would be nice too. Thanks!
    everything sucks but my vacuum cleaner.
    conjoinicorned
    Reputation: ferday's Avatar
    What alt bars? I've used 17,27,40 degree sweeps and drop bars....Marys are easily my favorite especially on the SS but drops are fun in a scary kind of way...They all set up different I'd be happy to share my experiences
    what would rainbow unicorn do?
    one chain loop
    i am thinking of a mary knock-off, the space off road 2. cosidered a drop bar but i think road levers is a prerequisite, so that's not happening. i am wondering though if my 70mm stem is long enough for an alt bar config.
    nothing to see here
    Reputation: Stevob's Avatar
    Carbon/Kevlar Ragley Carnegie's work well for me. 685mm, 25 degree sweep, 31.8mm rise with a bit of forward sweep and I use them with a Thomson 90mm 10 degree stem inverted.
    edit to add: I previously used Salsa ProMoto carbon bars with 17 degree sweep, no rise and also on a 90mm stem. The Ragleys stretch me a little bit further, but they're designed so that you won't need to change your stem if you swap from standard bars.
    I see hills.
    I want to climb them.
    conjoinicorned
    Quote Originally Posted by fishcreek View Post
    i am thinking of a mary knock-off, the gary off road 2. cosidered a drop bar but i think road levers is a prerequisite, so that's not happening. i am wondering though if my 70mm stem is long enough for an alt bar config.
    The marys forward sweep, not sure about the Gary? This means you can use your current stem...although I personally find 10-20mm longer works well as the different hand position can "feel" like you are closer in reach. On my trail bike I still use a short stem as I like the upright feel.
    The tilt of the bars is the most important thing, even a slight tilt changes the bar feel and height quite a lot. I like mine tilted quite a lot but you'll need to play with them and see.
    You would need brakes specific to drops to go that route.
    one chain loop
    Quote Originally Posted by Stevob View Post
    thanks steve, nice info and those ragley's are beaut. i am currently using 50mm on riser and the thing is dialed, so i still have to see if 70mm is good enough (hopefully).
    one chain loop
    Quote Originally Posted by ferday View Post
    sorry i meant origin8 space and not gary although i looked at the gary but like i said, i don't think i can get away without using a road lever. then i have to wrap my bars and be hipster like erik.
    Reputation: MMcG's Avatar
    Jul 2003
    My 44 Bikes SnakeDriver with 50mm Titec stem and a set of Ragley Carnegie Bars
    Feels mighty nice.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    I am not a huge fan of alt bars. I've had both of Misfit Pscyles FU bars, the Mary and something else... I liked the FU2 the best and used it for over a year. Then I put a riser with a 5 degree sweep on my commuter and I noticed I was getting more torque on it than my wider FU2. The Mary and the FUbar had too much sweep. 100mm on the FUbars, 80mm with the Mary, by the way, don't remember the angle, but not much. 15 or 5 degrees.
    I had a WTB drop bar too. Drop bars are pretty cool for descending. Once you are in the hooks you can keep your hands really loose without much risk of losing control. But I hated climbing with them, or navigating tech sections.
    So **** it. 660mm flat/risers are where it is at. As in the minimum. I have a 29" bar on my SS right now and I think it is amazing. Probably can't go much wider though, or I'll have to put my face on the stem. I use a 90mm stem with the 29" bar and 660 gets the 80mm. Makes no sense, I know...
    one chain loop
    i do have 28" bars and love it too except that i do experience numbness, tingling fingers once in a while.
    maybe i'll hate the alts or maybe not, i think it is worth the gamble. carnegies are sure drool worthy, and quite impressed with that 50mm stem. anyone willing to do a trade?
    I have a Misfit FME on it's way to me for a early 90's Blizzard build I am doing, they work with mtb brake levers. They are selling for $20 right now, FME Bar Handlebar - PSYCLESTORE , an inexpensive way for you to try drops.
    Reputation: rob1035's Avatar
    I've used Marys, Origin 8 Space Bar OR (now on my SSCX bike), and am currently running Misfit FUbars (with 100mm stem) on my Dissent, and they are perfect. I just wish I could get them in Carbon...
    I'm looking hard at the Carnegie Carbons, less sweep (25mm vs 33mm on the FUbar), but more rise (31mm vs 26mm) and wider.
    Stevob- How do the Carnegies ride? Any better or worse than a aluminum bar?
    nothing to see here
    Quote Originally Posted by rob1035 View Post
    I feel that they ride much better than the carbon Salsa bars I had. A little wider, giving more leverage for climbing, and (for me at least) the perfect amount of sweep back. I bought these bars looking for something stronger than the Salsa bars, with better climbing traits (width and sweep) and I got that but what I didn't expect from them was a huge increase in downhill control. I've gained so much more speed downhill now that I'm using the Carnegie's. Downhills were always my weak point. Now I'm just as fast (if not faster) than most of my mates who use squishy forks.
    As for comfort, there's no comparison between these and my aluminium Mary bars. The Carnegie's win hands down.
    The only downside is that the paint on mine is cracking, and they're yellowing a little too. They come in black paint or raw kelvar finishes also.
    I see hills.
    Jul 2003
    I'd like to give the Salsa Bend bars a go. The Carnegies are great, but I wouldn't mind a slighly wider bar for trail riding and leverage - something the Salsa Bend bars offer.
    The Carnegies are an improvement on the On-One Mary Bars IMHO because they are a bit wider than Mary Bars.
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    <a href="https://www.flickr.com/photos/davidandmelinda/6140686532/" title="IMG_4977sm by Melinda and David, on Flickr"><img src="https://farm7.static.flickr.com/6169/6140686532_d0db85e498_b.jpg" width="1024" height="683" alt="IMG_4977sm"></a>
    mary with a 70mm stem (I think it is short whatever length it is). I run the stem upside down for lower handlebar height. For me this is the killer technical AZ trail setup: rocky, tight, steep and loose.
    <a href="https://www.flickr.com/photos/davidandmelinda/6137992875/" title="IMG_5745 by Melinda and David, on Flickr"><img src="https://farm7.static.flickr.com/6204/6137992875_cb12829bab_b.jpg" width="1024" height="768" alt="IMG_5745"></a>
    I have used the fleegle and all assortments of handlebars from original Tange Prestige high bend cromo bars in the late 80's through no bend bars in the 90's through all kids of riser in the late 90's early aughts to the fleegle then the mary. The mary is hands down the best bar I have used since and especially so on a rigid application (which prior to fat front I was just using a standard 29er wheel and tire but it also is well suited to the fat front),
    MTBR Posting Guidelines
    calories>electrons
    poser Administrator
    Aug 2003
    Quote Originally Posted by MMcG View Post
    I have a Salsa Bend in the 23 bend, they aren't as bent as the Mary and aren't that much wider either. I will try to get a picture of them overlayed tomorrow.
    calories>electrons
    Quote Originally Posted by rockcrusher View Post
    Blah, blah... is that The Enabler you got there?
    poser Administrator
    Aug 2003
    Quote Originally Posted by umarth View Post
    soitenly is. Have had one ride on the setup, pretty amazing.
    calories>electrons
    Anything with a 2.4 tire? I've been thinking about picking one up, mainly for the water bottle bosses, but the peeps I am hearing is that the ****er is stiff.
    Sweet bike. Wish I had something like it. But I spend all my money convincing ex girlfriends to go with my to Swahili.
    Bro
    Bro is offline
    Content from my avatar
    Reputation: Bro's Avatar
    Dec 2010
    You called?
    I think I've been riding the Origin8 Gary dirt drops for about a month now? I like them a lot. Not something I would put on a mountain bike that sees technical stuff, because like umarth said, they're not so great for that. I like them for ascents as well as descents too though, because I don't even have to grip them while descending, and the drops give a lot of leverage for climbing. They're made for either a 25.4 or 31.8 stem, so that shouldn't give you problems.
    That said, I do run drop-specific brake levers. But that's also because there are no v-brake or disc bosses on the bike ('73 Schwinn Le Tour), so it's a lot simpler to just go with roadie-specific levers and brakes. I think you could run some flat-bar levers if you wanted to, though. They would obviously work on the top of the bar, and there's plenty of space on the drops if you wanted to be weird and mount the levers on the bottom of the drops instead.
    I can't remember how wide they are, pretty sure it's 530mm at the tips of the drops. They've got 135mm reach with 80mm of drop, and 15 degrees of flair from the top of the drop to the bottom. The very end of the drop portion is pretty flexy, so that makes rough riding on 28mm tires a bit nicer.
    Bonus? My roadie buddy hates the look of them, and says that I should just put some conventional drops on the bike. Hell nah I won't.
    Sometimes, I question the value of my content.
    The Enabler rides better than the KM fork it replaced on my bike.
    poser Administrator
    Aug 2003
    I wish i had a front 29er wheel to fit on there but it will have to wait as funds are short right now to build another wheel.
    calories>electrons
    Quote Originally Posted by Saddle Up View Post
    Sure, but the KM's stock fork is the stiffest ever. I rode one for a year and then was surprised that my 26" fork was soo much smoother. The rumor I heard on the Enabler is that the design is a little beefed up because of the eyelets.
    Quote Originally Posted by erik1245 View Post
    Tektro makes a long travel lever (520?) that is comfortable and works well. V brakes and discs should never be a reason not to use a drop bar. Especially if you have a SS setup.
    Jul 2003
    RL 520!
    Kaishingo
    Reputation: wuzilla's Avatar
    I put Gary's on my Surly earlier this year:
    At first I thought they were the bee's knees, but after the weather warmed up, and commuting miles started to overcome dirt road miles, I'm ready to take them off. Riding on the hoods sucks - but I guess everyone already knew that.
    Any pics of your setup? I swear the other Gary's I've seen looked a lot shallower w/ more flare (more towards WTB drops).
    Bro
    Bro is offline
    Dec 2010
    I didn't know that at the time.... And I was really wanting to try the dirt drops, and I wanted to do the build on Craigslist.... So I found some Cane Creek SCR-5 levers for $20.
    Quote Originally Posted by wuzilla View Post
    [pic]
    I've found that riding on the hoods is different.... Not exactly suckish, but it does take some getting used to. The Cane Creek hoods are way shorter/fatter than the Shimano hoods on my road bike though. I've always read that dirt drops are usually designed to be used more in the drops and tops than anywhere else anyways. Side by side, my road bike and my fixed gear with the Gary's have pretty much the same exact reach down to the drops. The flare does make it easier to ride in the drops though.
    Here's one of the first photos I took of the set-up.... I'll take a nicer photo eventually....
    Reputation: boomn's Avatar
    There have been two versions of the Gary, and so vastly different from each other that it is weird they used the same name
    Man, I'd love to find a pair of those Carnegie's to try out, they look great!
    Just ordered the Salsa Bend 2 bars with the 25mm sweep and a 90mm Thomson X4 with a10 degree rise. I'm hoping this feels right for my new Ventana El Com.
    one chain loop
    i would love to see that blizzard when its done. funny thing, it is cheaper to buy it in USD than in CAD$
    It's got a minty XT drivetrain that shall remain on so I won't be able to post it in this forum, I'll post it in the Rocky forum next week after the bar arrives. The bike is being repurposed.
    I purchased in USD, I have a frame and fork coming also, that are SS. I wonder if Misfit deal with overseas manufacturers in USD?
    Bro
    Bro is offline
    Dec 2010
    We want photos of the bike, dammit. We're ok with geared bikes.
    Most of the time.
    one chain loop
    review
    got mine and loving it. i like the knee clearance when cranking off the saddle, plenty wide and hands is in relaxed position. mind you, this is my commuter so i can't relate it when going downhill and turning on technicals. downside for me is it turns slow and understeer, maybe not used to it still. but for commuting on straights, leverage and knee clearance, i give it 4/5.
    using 70mm stem with 0 deg rise.
    Just A Mountain Biker.
    Reputation: blaklabl's Avatar
    Mar 2011
    OMG that Breezer is DOPE! I can never find anything good like that to build up as a 2nd bike.
    I just received my Salsa bend bars in 23 degree and an 80mm 25 degree Salsa Pro-Moto stem (replacement for the recalled Cro-Moto), and I am stoked to get them on my XXIX this weekend. I went with the higher rise stem to try to get my bar height up a bit, mine is the non-suspension corrected version and with the short head tube on the medium I stuggle with getting my bars up enough to not cause lower back pain without using a ton of spacers. I'll post a pic when I get them mounted up.
    Reputation: schmed's Avatar
    I've got the Carnegie carbon bar on my GF Rig. Had a carbon bar with a slight arc prior to this. Both were good, but I have less fatigue with this one. Great control, great feel, and looks like a "townie" bike (so says a buddy of mine.)
    Schmed
    2001 Turner O2 XC
    2012 IndyFab Planet Cross CX
    2013 Kona Raijin SS
    2016 Scott Big Jon
    conjoinicorned
    fishcreek, that is a sick ride! clean lines, absolutely beautiful.
    ^yep
    dirtbag
    Reputation: ranier's Avatar
    Sep 2003
    Very nice Breezer fishcreek but how the hell is that bike standing upright by itself?
    Amolan
    Origin8 bar/stem for me
    They are so comfy It's rediculous!
    Reputation: ThreeD's Avatar
    Ragley Carnegies
    I've got the Carnegies on my Singular Swift and couldn't be happier.
    Attached Thumbnails Attached Thumbnails Rigid + Alt BarSS-2011-09-24_10-40-04_496.jpg
    Is that Bill rated?
    Reputation: Lord Humongous's Avatar
    I have tried Marys, too flexy by far; Carnegies, not enough control space leaving my brakes too close to my grips; and Fubars which have turned me back into a rigid riding monster. Don't worry about specifics, what works for me in stem length and pitch of the bars may not for you. I tend to prefer a short effective stem and bars that turn down at the ends even when using conventional bars so I have about fifteen degrees of downturn and use a 100mm stem which puts my hands around where a 60-70 stem would put me with a nine degree conventional bar.
    Well, it was a good try.
    nothing to see here
    Quote Originally Posted by Lord Humongous View Post
    ...Carnegies, not enough control space leaving my brakes too close to my grips...
    I'd love to know how freakishly long your grips are.
    I see hills.
    one chain loop
    Quote Originally Posted by LittleBuddy View Post
    beautiful sawyer, man
    Jul 2003
    Inverted my Ragley Carnegie Bars and paired em up with a 50mm Titec Stem - really comfortable configuration.
    I just realized that I may actually have an "alt" bar fetish. I just received the Misfit FME, it's the one in the back. I needed it because it's unlike any other bar I own.
    I have these bars because traditional bend road drops are for freaks and weirdos
    for SS bikes intended for the track the bar needs an "alt" bend also
    Salsa Bend 2 Bars
    Not sure I'm completely satisfied. I like the sweep. Not sure I have enough rise. Using a 90mm,10 degree stem. The bars seem wide at 715mm. May cut them down 10mm per side.
    Reputation: Mr_Nice_Guy's Avatar
    Quote Originally Posted by Technogator View Post
    I just got a set as well, I like them but I also swapped out my stem for a Salsa Pro-Moto 80mm 25 degree rise and it got them up where I needed them. I was coming off a 1.5" riser bar and a 90mm x 6 degree rise stem. I was afraid the stubby high-rise stem would look goofy, it doesn't look bad at all.
    Quote Originally Posted by Mr_Nice_Guy View Post
    Thanks. Check out the Ventana setup thread for more pics.
    one chain loop
    got enough bars there? how wide are those soma's?
    one 490mm in black and 520mm silver and black
    warning geared content
    the Blizzard as requested. The idea with this bar was to shorten the reach. Ideally I ride 16.5"-18" bikes, this 19" was just slightly long. I have long legs for my height so standover is rarely an issue. I tried the FME in the drop position, the reach was okay but it was needlessly low. With the bar on the rise this bike is supremely comfortable and a real gas to ride.
    Reputation: SSPirate's Avatar
    Oct 2011
    The Ragley Carnegie's in a riser, carbon look like the ticket! Rise and back sweep...Heaven.
    one chain loop
    Carnegie's are on sale at Chain Reaction with FREE shipping.
    Dec 2008
    What bar is the second to last one there? Between the last sparrow and the FME? Thanks!
    I'm rocking Misfit's FUbar, and really like them, but would like something wider (they are 635mm). Maybe the Salsa?
    Dec 2008
    Quote Originally Posted by bennymack View Post
    PMed Saddle Up and found that the 4th bar is an FSA Metropolis. Thanks, Saddle Up! I'm so putting one on my SS commuter.
    nothing to see here
    They've been that price forever, but the free shipping is a big bonus.
    I see hills.
    Reputation: Houndog45's Avatar
    Oct 2010
    I love mine!!!!
    I couldn't imagine going back to reg style bars..
    I finally swapped out my too narrow old-school flat bar to a Felt Albert bar I found on ebay.
    Man, I can't believe I rode so long on the old bar! A buddy loaned me a bike with a "typical bar", and it actually took a while for my wrists to get used the lack of sweep.
    EXORCIZE
    Reputation: Ryder1's Avatar
    Previous alt bars: Mary, Mary-like custom ti, Titec h-bar, Carnegie carbon, and an Origin8 Space OR2 (on current SS rigid). Ran a Mary for awhile and loved it so much I got a ti version built for me but a bit wider. It broke pretty fast. Got the Titec h-bar b/c it was a bit wider than Mary - ok, but very heavy, very stiff, and very ugly. After one ride on the Carnegie carbon bar, I sold it - not enough sweep and felt flimsy IMO (and I like carbon bars). The Space OR2 is basically perfect for me, although I'd prefer carbon for the comfort. Weight and looks is better than Titec h-bar and seems more comfy (relatively speaking). If I couldn't get the Space OR2 (tough to find), I'd probably put my Monkeylite 710 carbon riser on instead.
    A Gentleman and a MTBR'
    I have a set of Origin8 "Classique Tour" bars which are apparently "off road rated" I've ridden them upside down and right side up, both were comfy. I'll post a pic later this afternoon.
    weekend warrior
    Reputation: Lenz43's Avatar
    I have two sets of carnegie's on geared and suspended bikes, On the SS bikes I like my Jones bars:
    Common sense was never common
    The N9 loves the Carnegie's
    Attached Thumbnails Attached Thumbnails Rigid + Alt BarSS-img_4195-medium-.jpg
  67. #67
    What is up with this current trend of ridiculously swept back bars on mountain bikes? do any of you guys ride aggressively? I just can't imagine using anything but a wide riser for aggressive mountain biking. Anything with more than 9 of backsweep makes me feel like I'm riding a cruiser. Terribad for climbing.
    I'm curious about dirt drops though, they look like they could have some advantages but I personally feel like they look like @$$ with the slanted down drop levers on them.
    Who started this trend??
  68. #68
    Bro
    Bro is offline
    Dec 2010
    Quote Originally Posted by TruTone View Post
    You have much to learn, young Padawan.
  69. #69
    Oct 2010
    I can ride plenty "agressive" with mine...I find them better for climbing as well..
  70. #70
    My other bikes are Tazer VP with chromag 760 bar, Tracer 2 with 750 Spank bar and Banshee WC with Loaded 780 bar.
    I don't feel less aggressive with that bar, I do everything with it and I just like it
  71. #71
    one chain loop
    The On-One Mary is very similar to the Origin8 Space OR2. same sweep, reach and width.
    The Space OR2 has longer grip area though.
  72. #72
    Former Bike Wrench
    In the spirit of cheapness...my Dawes "Huffy" is sporting Nashbar Comfort Mountain bars cut to 680mm with a 30* sweep with a generic 100mm x 8* stem
  73. #73
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by mtnbiker72 View Post
    That bike is so cool, nice work.
  74. #74
    EXORCIZE
    Or2 ftw!
    [/IMG]
    My OR2 is wider than my Mary (at least 10mm wider). When I bought the OR2, I was surprised that its packaging listed the width as 675mm (IIRC) - Origin8's website lists it as 655mm.
    Also, just from the feel/look, I'm not convinced the OR2 has quite as much backsweep as the Mary (though it still has among the most). But maybe.
    The OR2 is heavier and available in 31.8 (i.e., significantly stronger/stiffer). I believe the Mary was eventually deemed not fit for off-road abuse by its maker.
  75. #75
    Reputation: donmeredith74's Avatar
    Rigid + Alt Bar SS
    I dig my bars (Black Sheep)... wide and offer a bit of compliance.
  76. #76
    Jan 2009
    I have some experimenting to do.
  77. #77
    Reputation: drofluf's Avatar
    Dec 2010
    Not on a rigid but...
    Singular Swift with Mary BArs by paulfulford, on Flickr
    I find that they put my wrists in a more comfortable position than conventional bars, especially for longer rides
  78. #78
    Where'd you get those Huffy decals?
  79. #79
    Quote Originally Posted by donmeredith74 View Post
    It'd be good to see more of that bike!
  80. #80
    Rigid + Alt Bar SS
    James-O,
    You don't have to ask me 2x to show more photos of the Black Sheep!
  81. #81
    Feb 2010
    Has anyone used Clarence bars?
    "Never try to teach a pig to sing. It wastes your time and annoys the pig." -Mark Twain
  82. #82
    Former Bike Wrench
    Quote Originally Posted by pulsepro View Post
    Ebay
    Huffy 4130 Stickers Decals White, Silver & Black. | eBay
  1. Replies: 44
    Last Post: 10-03-2011, 07:48 AM
  2. Rigid to suspension back to rigid......
    By njbiker66 in forum 29er Bikes
    Last Post: 05-01-2011, 07:46 AM
  3. How rigid is a rigid carbon fork?
    By seemana in forum General Discussion
    Last Post: 08-12-2010, 03:56 PM
  4. Rigid Spam .... Wanted 29er Rigid Fork ...see add
    By MichiganClydesdale in forum 29er Bikes
    Last Post: 01-11-2007, 07:02 PM
  5. Replies: 9
    Last Post: 12-05-2006, 10:19 AM
