Removing the freewheel- Mtbr.com
Results 1 to 13 of 13
    c-d
    c-d is offline
    Looking for help or tricks in removing freewheels. My 12" crecent wrench with a 5 lb hammer and appropriate Park freewheel tool was just not enough. Yeah, I know it was a few steps below shop work.
    KgB
    KgB is offline
    SNGLSPD
    Reputation: KgB's Avatar
    here's what I do
    Attach the freewheel tool loosely with the axle nut.
    Put in vice and turn like steering wheel(lefty-loosey)
    If you don't have vice you may need two people and a pipe to fit over wrench for leverage.
    When you reinstall use never-seize not grease.
    I've been inside too long.
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    this always works for me
    hold the wheel upright (might need to bolt or nut the fw tool in place), and step on the 12" crescent wrench. I use a Park chain whip, which fits the fw tool; it's a little longer but not much. You might need a cheater bar for more leverage. Others use a vise.
    Reputation: Cygnus's Avatar
    old trick
    The vice works well. I use that as well as on old trick learned on this board. take a long piece of wood, e.g., 4x4", and nail some pieces of wood molding that will hold a big crescent wrench in tightly place on top. i kneel on the big piece of wood, or brace it in a corner, with crescent wrench and socket in place, while turning the wheel. the wheel gives good leverage (as it does on the vice), and the wood acts like a vice-like support. make sure to use grease or anti-sieze on the threads when remounting.
    More leverage?
    When I need a little more leverage than the standard tool provides, I use some thick schedule PVC pipe that's a good length, slip it over the tool and it gets the job done. Plus, the pipe is a little easier to grip than the original tool.
    Use your QR skewer or axle nuts to lightly hold the tool in place. Give it enough slack to make the initial turn when it breaks loose.clamp the tool in a bench vise, grasp the wheel by the outside edge, and apply steady pressure until it moves. Back off on the skewer nut, and turn until it comes out. After the first full turn, they usually come off with hand pressure.
    Freewheels loosen in the direction that they freewheel.
    The man who fell to earth
    Reputation: Ziggy-Stardust's Avatar
    try this....
    The tool in the vise/turn the wheel with your hands method usually works pretty well. But some people don't have vises, or even if they do this technique may not work for a really stubborn one.
    An easy way to get it off every time is to take your wheel (complete with stuck freewheel) and your freewheel tool to your friendly local auto garage/tire outlet (Firestone, Goodrich, Joe's Garage, whatever). Try to bypass the counter and go directly to one of the mechanics and ask him if he can zip it off for you with his pneumatic impact gun (the pistol looking thing they use to quickly put lug nuts on and off with). It will only take a second (literally), so they should do it right then and there and won't charge you. If they give you any grief try another place, but most mechs would be happy to do it for you. Those impact guns WILL get your freewheel off!
    Good luck...
    Quote Originally Posted by c-d
    good ol wrench for plumbing?
    this could work with a FW tool if a vice isnt' avaliable. more leverage and wont hurt the hands as much as a skinny commuter tool.
    [zip it off for you with his pneumatic impact gun (the pistol looking thing they use to quickly put lug nuts on and off with).
    I thought about suggesting this myself. I have an impact at home and find that it gets things lose with less damage than using brute force and a cheater pipe.
    "I've never been better .... nor cared less!"
    DSR
    DSR is offline
    I've broken a 12" wrench this way. I stomped on it and the FW tool just ate into the wrench. I didn't have a vice, so I picked up a socket (25mm I think?) and borrowed a buddies big socket wrench and then threw a 2.5' cheater pipe over that and really leaned into it. After a couple big pushes it gave way. The socket fits onto the FW removal tool real snug. Man, those FW's can really get on there tight after standing on them up the hills for a couple months. S
    I second the impact wrench...
    I just went a few rounds with one I had used for over a year and I couldn't budget it with a big wrench but the impact finaly spun it off the hub. I set the wheel on a cardboard box and barely held it between my leg then proceeded to "hammer the Sh!^ out of it till it broke free.
    Everybody keeps suggesting a vise, I like to use my teeth.
    KgB
    KgB is offline
    SNGLSPD
    Impact
    [QUOTE=Ziggy-Stardust]An easy way to get it off every time is to take your wheel (complete with stuck freewheel) and your freewheel tool to your friendly local auto garage/tire outlet (Firestone, Goodrich, Joe's Garage, whatever). Try to bypass the counter and go directly to one of the mechanics and ask him if he can zip it off for you with his pneumatic impact gunQUOTE]
    Hey that's a great idea.
  1. disc + freewheel + fixed gear?
    By qtip in forum Singlespeed
    Last Post: 02-13-2004, 08:04 PM
  2. Ringle Bubba Freewheel Hub
    By TT. in forum Singlespeed
    Last Post: 02-05-2004, 09:18 AM
  3. Rough freewheel (I think) question...
    By DSR in forum Singlespeed
    Last Post: 01-29-2004, 08:40 PM
  4. Removing disc tab from anodised frame.
    By Gaz in forum Weight Weenies
    Last Post: 01-21-2004, 03:54 AM
  5. Losing preasure when removing pump?
    By Lambone in forum Shocks and Suspension
    Last Post: 01-19-2004, 09:01 AM
