Removing cog from alloy freehub- Mtbr.com
Results 1 to 8 of 8
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    Any tricks to getting of a jammed cog from the freehub body? Thanks
    master blaster
    Reputation: veloreality's Avatar
    this happened on my king after converting it to ss for a bit.
    1) i was using a cheap thin steel cog
    2) i layed the wheel down on the ground, stood on the edges and pulled the guy off.
    3) i replaced the cheesey cog with a origin 8 cog (affordable, stong, super wide profile, looks nice)
    Quote Originally Posted by ISuckAtRiding View Post
    The dude is like 120lbs, tops lol he can run any tires he wants without issues, i'm sure.
    nocturnal oblivion
    Mar 2006
    I must have delicate hands! that's tough. It is an origin 8 cog btw.
    is buachail foighneach me
    Reputation: sean salach's Avatar
    I would think if you had a chain whip, you could put another cog on there, lightly tighten down the lockring, mount the wheel up on the bike, and use the chainwhip on the second cog in the opposite direction.
    nocturnal oblivion
    Mar 2006
    It's on a shimano spline type freehub body, I'm trying to pull it straight off.
    Reputation: Velobike's Avatar
    Sean's idea is worth a go.
    It sounds like your cog has embedded itself in the metal of the freehub. By having another cog on it to use as an anchor and then turning your cog in the opposite direction to normal rotation you may (or may not ) free it enough to remove.
    Latitude: 5736' Highlands, Scotland
    nocturnal oblivion
    Mar 2006
    Ahh, I see what you mean. Thanks, I'll give it a shot.
    Quote Originally Posted by sean salach
    ^^^ This.
    This is about the fourth thread this morning I've looked at, where you've already given the exact advice I would have. GET OUT OF MY HEAD!!!
