Removing cantilever studs- Mtbr.com
Results 1 to 8 of 8
    Reputation: hozzerr1's Avatar
    Feb 2005
    Anyone experienced problems removing the cantilever/v-brake studs off a rear triangle MOTOBECANE?
    These studs are rounded at the base with out the flat spots for a wrench.
    I am afraid that if I squeeze them with a lock channel they are going to crush...
    Any suggestions?
    thanks.
    Feb 2006
    Disc brakes are a fad, just mount some v brakes to them.
    If that doesn't work and you crush them with channel locks, go full bubba with a dremmel and then smooth it over with some JB weld.
    Reputation: t3mplar's Avatar
    Jun 2013
    you could find a bolt with the same thread and thread the bold into the v-brake studs; that should reduce the chances of you crushing them.
    good luck.
    Feb 2005
    I am fixed and wanted a cleaner look, but want to be able to use them again when SS
    Reputation: vaultbrad's Avatar
    Oct 2007
    Put them to use and mount up an Old Man Mountain rack to the posts. Then you have an even more useful bike.
    Feb 2005
    Well forensic revealed these are not removable, so they'll have to stay since they'll be needed for future duties.
    Even if you aren't using them, it is prudent to thread a bolt in to keep muck out. I don't know if the end user can buy these, but a few companies ship their bikes/forks that have optional canti studs with a plastic cover.
    They're quite snug, but ugly as hell.
    Feb 2005
    Quote Originally Posted by wschruba View Post
    Jenson USA sells these plugs for the stud holes, I've seen those you speak of too.
  1. Replies: 82
    Last Post: 11-28-2015, 10:19 PM
  2. Removing Monocog brake studs?
    By AmericanTemplar in forum Brake Time
    Last Post: 06-20-2013, 08:26 AM
  3. Replies: 2
    Last Post: 10-30-2012, 01:05 PM
  4. Adding Cantilever Studs to Carbon Frame/Fork
    By DirtRoadie in forum Frame Building
    Last Post: 02-04-2012, 11:50 PM
  5. Removing stickers w/o removing rack paint?
    By jrm in forum Cars and Bike Racks
    Last Post: 05-20-2011, 08:25 AM
