removing belt-drive cog?- Mtbr.com
    viva la v-brakes!
    Reputation: FishMan473's Avatar
    Jan 2003
    My wife has a new Raleigh XXIX, and the belt keeps falling off. It looks like moving a spacer on the freehub might fix the alignment, keeping it on track.
    Trouble is, I can't figure out how to remove the lockring from the freehub. I can't exactly put a chain whip on it to keep the cog in place, so how do I back-off the lockring... I need a way to keep it from spinning.
    FWIW, I don't have any experience with a freehub style single speed set up, I have freewheels on my bike, so maybe there's a simple solution that I"m missing.
    I have a car. I made a choice. I ride my bike.
    I had to put the rear cog in a vise to hold it from spinning. There is a tool for removing the rear cog but I don't want to spend the bucks for something I'd rarely use.
    You can do it with an oil filter wrench/strap wrench. I also use them for removing the rear can on air shocks. Try lowes or home depot.
    Reputation: SSSasky's Avatar
    I definitely would avoid the vise method - you could damage the teeth on the cog, which could in turn damage the belt. Use the oil filter wrench. Cheap and effective.
  1. I'm DONE with Belt Drive!
    By drMP in forum Singlespeed
    Last Post: 04-30-2011, 10:29 PM
  2. New Belt Drive
    By Velobike in forum Singlespeed
    Last Post: 10-04-2010, 05:31 AM
  3. Belt Drive
    By frank daleview in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-29-2010, 10:21 AM
  4. Belt drive?
    By jollybeggar in forum General Discussion
    Last Post: 09-30-2008, 07:04 PM
  5. Belt drive SS
    By datako in forum Singlespeed
    Last Post: 09-26-2004, 04:03 AM
