Regular Chain Tool w/ 1/8 Chain- Mtbr.com
Results 1 to 5 of 5
    you go ahead
    Feb 2005
    Every time I take apart and re-connect my Sram PC-1 chain (1/8), I get a stiff link. I went on the park tool website and they said something about chain tools having to be different for different sized chains?
    If it's true, then could I use an 8 speed chain on an ss cog & chainring?
    thanks
    Cubicle Fugitive
    Reputation: czardonic's Avatar
    You can loosen the link by grabbing the chain a few links away on either side and flexing it back and forth laterally. This spreads the plates out a bit. But why not use the removeable link? Breaking and re-closing the chain just makes it weaker.
    To answer your questions, it depends on the cog and chainring, but unless you went out of your way to buy 1/8" components instead of 3/32" the answer is probably yes.
    Reputation: pacman's Avatar
    Quote Originally Posted by RustyBearings
    thanks
    Tight link? http://parktool.com/repair_help/FAQtchan.shtml
    Get a BMX link and you won't need a chain tool.
    Reputation: shiggy's Avatar
    Dec 1998
    thanks
    I never use the chain tool to connect an 1/8" chain. I use master links. If I change my gearing and need a longer chain I use another master link to connect the new 2-3 chain links.
    Go back to the old gearing, open the MLs and remove the short piece.
    mtbtires.com
    you go ahead
    Feb 2005
    well I used the part of my chain tool that supposedly gets rid of tight links. It worked, but now when I ride on it, my chain is constantly derailling (with a nasty crack first).
    I don't know if this still means I have a tight link or if it is a cause of improper chainline or lack of chain tension (still need a tensioner)
  1. popped a chain link -- time to replace chain??
    By journey in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2005, 03:27 PM
  2. Should I shorten my chain?
    By Vulcan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2005, 09:20 PM
  3. What do you use to lock up your bike?
    By LavaPunk in forum General Discussion
    Last Post: 02-06-2005, 01:20 AM
  4. Good info on bike locks.
    By 2melow in forum General Discussion
    Last Post: 02-06-2005, 01:02 AM
  5. Noisy chain when in middle ring- HELP!!!!!!!
    By HPilot in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-01-2005, 10:49 AM
