Recommend a chain tug compatible with Paul WORD hub.- Mtbr.com
Results 1 to 7 of 7
    AKA Pat McGroin
    Hi all, have been running a WORD hub on my steel Inbred and last night at Ray' Indoor bike park on a super steep climb we call the corkscrew, bam! Wheel cocked sideways, chain fell off and I nearly did a backward somersault.
    The frame has horizons dropouts or track ends, and until now I haven't used anything to hold the wheel in place, just kept the bolts tight! When I first installed this wheel, I wasn't able to use my trusty Redline branded chaintug as the axle diameter was too large, so I always check the bolts before and after every ride...often the chain tension was a bit loose, but now it lets the wheel slam the tire into the chain stay a lot, and it did it a 2nd time shortly afterward. I had to be careful not to torque too hard on the many short climbs.
    Anybody run WORD hub have a chaintug device they can recommend?
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    surly tuggnut should do it
    they are way tougher than that redline stuff
    AKA Pat McGroin
    That would be on my short list. Also saw a nice set fromProfile Racing.
    Oct 2013
    Just get the appropriate sized drill bit and drill out the cheapo Redline tug. No cost and an immediate solution.
    Reputation: dbhammercycle's Avatar
    MKS chain tugs are pretty good
    Perhaps have a look at some BMX offerings.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    very simple; if it slipped your bolt wasn't tight enough. also maybe rough up the paint a little if it is a new frame so the bolt has better purchase. you don't need a chaintug...
    keep singlespeeds simple.
  1. Paul WORD vs. Surly Hubs?
    By mdilthey in forum Singlespeed
    Last Post: 11-29-2016, 07:35 AM
  2. Paul disc Word + WI Eno freewheel?
    By verrocchio100 in forum Singlespeed
    Last Post: 08-20-2015, 10:18 AM
  3. Paul Word Hub and 6 speed freewheel?
    By Mr Pink57 in forum Commuting
    Last Post: 03-30-2015, 08:40 PM
  4. Replies: 0
    Last Post: 11-29-2013, 12:14 AM
  5. Using disc side of Paul Word SS hub for fixed gear?
    By TwigJumper in forum Singlespeed
    Last Post: 04-13-2012, 04:08 PM
