Recommend a 20t cog- Mtbr.com
Results 1 to 18 of 18
    Dec 2010
    Recommend a 20t cog
    Need a 20t cog for my Monocog. Don't know which cog and new chain to buy. Any help?
    Reputation: bycyclist's Avatar
    Get steel.
    Cheap - Surly 20T for about $20ish
    Expensive - Chris King 20T for about $45ish
    Dec 2010
    My question is more because i'm new to this. Are all 20t cogs the same? Is there a certain type I need for a monocog?
    You need a splined cog and not the threaded (screwed on) kind. Surly works fine. ISuckatRiding's are puurty.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Do ISAR. It is the best choice on a lot of levels.
    Reputation: asphaltdude's Avatar
    Gusset stamped steel cog lasts loooong and costs next to nothing.
    Ride more!
    Dec 2010
    Quote Originally Posted by asphaltdude
    But stamped cogs wear away the freehub body much faster, get something with a wide "foot". Yeah a $5 cog may be tempting but spend $20 more and save yourself in the long run.
    Reputation: ianick's Avatar
    Quote Originally Posted by sasquatch rides a SS
    +1
    The stamped cog I used entrenched itself into my freehub body in 1 hard ride. Zero problems with wide base cogs(Surly).
    Dec 2010
    +1 on the Surly. That's what I use as well
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Surly or go with ISAR for the bling.
    Dec 2010
    I think ISAR needs to make fixed cogs that bolt onto the rotor mount Hipster AND stylish
    Reputation: lwebber60's Avatar
    Endless Bike Company's Kick-Ass-Cogs, great product!
    "At a full quarter inch wide (6.35mm) at the splines, Kick-Ass-Cogs simply will not damage your free hub body the way a narrower cog can. Made of high strength 7075-T6 alloy (Stronger and harder than most common steels), Kick-Ass-Cogs are precision machined insuring perfect axial and radial alignment that compliments the superior chain lines that cassette style hubs allow.
    The specially engineered tooth profile on Kick-Ass-Cogs improves both cog and chain life while minimizing drive train friction. With a Kick-Ass-Cog on your bike, you can expect a smooth, quiet drivetrain for miles to come.
    Like all EndlessBikeCo. Products, Kick-Ass-Cogs are made right here in Western North Carolina; not in some faceless factory on the other side of the planet."
    2008 Trek 69er SS
    2010 Vassago Jabberwocky SS
    Dec 2010
    Not sure about the 7075-T6 alloy and how good it is but I still think stainless steel is a better choice for cogs
    Out spokin'
    Dec 1999
    +1 . The more you ride your bike, the more it matters.
    --sParty
    disciplesofdirt.org
    Dec 2010
    --sParty
    Well if if the OP doesn't ride much and it doesn't matter I'd just suggest skipping the alloy and go with those shattty stamped cogs that someone suggested earlier
    Reputation: Brewtality's Avatar
    Does anybody from Gusset post up on MTBR?
    What about Surly? King? Endless? If any of them are, I have never seen it.
    Support those that support the forum.
    I know ISAR is on here all the time.
    Homebrewed Components
    His thread is just a few threads down on the SS forum.
    Its all Shits and Giggles until somebody Giggles and Shits
    Reputation: Joe V's Avatar
    Jan 2011
    +1 for ^^^ homebrewed, killer looking stuff, I have a order in now for a cog, chainring and nut tuggers
    I have over 700 miles on mine, and it still looks like new... although last summer was very dry up here in New Hampshire. I'm sticking with em' till there's a reason to change!
    2008 Trek 69er SS
