Rear Cog's Steel, Aluminum, or Ti- Mtbr.com
Results 1 to 32 of 32
    I was thinking of changing my rear cog, and I was wondering what material held up the best Steel, Aluminum, or Ti.
    I currently have a Surly 22t, but I think I am ready to drop down a tooth to 21t.
    Reputation: cockroach's Avatar
    Simple answer....steel.
    Aluminium isn't up to it for a rear cog, and while titanium is lighter than steel it's not as strong.
    I use the On-One groove armada cogs, super strong cro-mo.
    Feeling retro..but Jung
    Reputation: Germany_chris's Avatar
    my DA cassette is alu and ti it seems to hold up..my SS cog is steel...long term durability steel..but dont rule any out..
    Reputation: Cholopolitan's Avatar
    Steel
    I've found aluminum does wear quicker. For fully-geared bikes, aluminum is fine since wear is more distributed. I have no experience with ti.
    Jan 2005
    ti and aluminum dont hold up well but are both very light.
    jesus rides a fixed gear.
    Reputation: boomn's Avatar
    Quote Originally Posted by KonaEnduroJC
    Ti SS cogs are known for holding up for a very long time. It is a much harder material than aluminum. I would always choose steel over Ti though, but that is simply based on price
    Thanks for the input, looks like I will just stick with the Surly, and get a 21t. Thanks!
    Beware the Blackbuck!
    I'm sure ti holds up well, but I have a feeling ti longevity has a lot to do with how often people are changing out their chains to keep from ruining an 80 dollar cog...
    Quote Originally Posted by ShadowsCast
    I don't know the numbers off the top of my head, but titanium is pretty similar in hardness and strength to stainless steel.
    A bit off topic and certainly not the definitive answer on Ti hardness. Had a Ti seatpost clamp several years ago. Bolt stuck out too far so I grabbed a hardened steel coping saw blade intended for cutting metal. Got absolutely no where trying to cut that bolt. I had always thought Ti was like Al in that it was strong and light, but not necessarily hard. Trying to cut that bolt changed my opinion.
    Not directly cog related, but DMR do a titanium axle for their V12 pedals.
    From their website:
    "Maximum rider weight is not to exceed 185lbs or 85kgs".
    But they are 80g lighter than the standard steel.
    singletrack bound
    Reputation: Tone No Balone's Avatar
    Dec 2004
    Here's a pic of an alum cog further on down the thread list!
    steel is real!
    Attached Thumbnails Attached Thumbnails Rear Cog's Steel, Aluminum, or Ti-broken-ck-cog.jpg
    Reputation: OldHouseMan's Avatar
    I'm pretty sure Chris King stopped making the aluminum cog and only makes steel.
    I only ride bikes to fill the time when I'm not skiing.
    blame me for missed rides
    Reputation: weather's Avatar
    Quote Originally Posted by boomn
    surface hardness is comparable, but elastic and shear moduli are about half as much as 304 stainless.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Photo credit to dzm3,
    Attached Thumbnails Attached Thumbnails Rear Cog's Steel, Aluminum, or Ti-kickedasscog.jpg
    Reputation: scooter916's Avatar
    Quote Originally Posted by Germany_chris
    actually the carrier is the only thing alloy, the cogs are steel and Ti
    Quote Originally Posted by thefuzzbl
    aluminium has a tendency to fail when you need it most. i.e. you end up with a bad day.
    Pwning Trails
    Reputation: phlite's Avatar
    Dam, that cog is f'd .. aluminum i presume?
    Out spokin'
    Dec 1999
    Quote Originally Posted by phlite
    Yes, aluminum.
    --Sparty
    disciplesofdirt.org
    Pwning Trails
    So, it sounds like steel for the rear cog, but you could go either way for the chain ring? I was looking at the surly steel chain ring, to upgrade my stylo 1.1 ring, in hopes of getting rid of tight places in the chain. But, reading around the singlespeed forum, looks like the surly steel chain ring can get bent fairly easy?
    Thoughts on chain ring? Was looking at possibly ISAR alum chainring ... or if not alum, better steel ring from somewhere else? Thanks!
    Out spokin'
    Dec 1999
    Personally I prefer not to run aluminum rings or cogs on any of my bikes (geared or SS) simply because steel outlasts aluminum. I employ Surly rings but my cranks are all 5-bolt spiders which means there's less of a span between ring bolt holes so they're less likely to fold (although I've seen a photo of a folded 5-bolt Surly ring. It may have lost a CR bolt prior to folding, tho.)
    ISAR makes aluminum, ti and I think he still offers steel rings & cogs. Until a rich cougar catches me, I'm probably stuck with Surly cuz they're cheap and they work. I put a lot of miles on my bikes, therefore I don't care to invest a lot in wear items. If I was more bling oriented, I'd def be one of ISAR's top clients.
    --Sparty
    disciplesofdirt.org
    I've got a 33T Surly ring with many many miles and seen several cranks. No issues. I'm not sure how people bend these things. Maybe bad chain alignment? Bolts not tight? Don't know.
    I use Surly due to price and availability.
    Come see me after class
    Dec 2005
    i run Salsa rings (aluminum) and have yet any issues with failure or wear. maybe i just don't ride long or hard enough... that just sounds dirty.
    Mtbr Forum Sponsor - Homebrewed Components
    the ti and steel i use are fairly similar in strength. Close enough to where you wont notice much of a difference in wear life. The ti i use is 6al4v, and the stainless is 17-4ph, both of which are pretty tough aerospace alloys.
    As for aluminum, for chainrings, i think it's fine. You'll probably get at least a season out of it with normal lubing. Sometimes more, sometimes less, depending on where you ride. As far as aluminum cogs go, they do wear out rather quickly, no matter what alloy you use. There is much less chain wrap on a cog than a chainring, so each tooth is getting about twice as much load. I usually say save these for race day.
    Quote Originally Posted by p nut
    It's because they use 304 stainles steel, which is butter soft.
    the yield strength for 7075 aluminum is 73000psi, and the yield strength of 304 stainless is 42100psi.
    and for example, the yield strength of 17-4ph stainless is about 145000psi, and 6al4v titanium is 128000psi.
    Yield strength is the lowest stress at which permanent deformation can be measured.
    Pwning Trails
    Ok, thanks, so Surly rings even 4 bolt, 180mm cranks are probably good for mere mortals hopefully. I was worried about bending, probably worth a shot anyhoo.
    Out spokin'
    Dec 1999
    Quote Originally Posted by ISuckAtRiding
    So will your steel rings last ~3x longer than a Surly steel ring? If so, I might step up. Thanks.
    --Sparty
    disciplesofdirt.org
    --Sparty
    Well, i dont make stainless chainrings because that alloy is hard to get in the size needed to make them. It would actually cost more than ti.
    As for the cogs, surly uses an alloy steel instead of stainless, which i think will probably carry similar properties to my cogs. They dont state exactly what alloy they use, so i'm only assuming based on my experiences with the most common types.
    Also, yield strength has more to do with the taco issue than wear life. Any steel ring should have a much longer wear life than aluminum.
    Out spokin'
    Dec 1999
    Keep your chainring bolts tight. Everything should work out fine.
    --Sparty
    disciplesofdirt.org
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    Quote Originally Posted by cockroach
    really now, im pretty sure Ti is stronger than steel, look it up, get the facts.
    as for the price Ti as you know is more expensive so if you want function over form choose an SS ring
    "If women don't find handsome , they should at least find you handy."-Red Green
    Out spokin'
    Dec 1999
    Quote Originally Posted by nuck_chorris
    That's it, Nuck... take him to task for failing to do his homework.
    --Sparty
    disciplesofdirt.org
    too generic a statement to make. As ISAR pointed out, there can be a huge difference in strength and hardness between different steel alloys. Some Ti alloys are stronger than some steel alloys and some steel alloys are stronger than some Ti alloys
    fine , ill be more specific , A stamped steel cog versus redline's flight titanium cog. the cog will have greater or equal strength to the stamped cog not less strength with an added bonus, weight savings
