Results 1 to 8 of 8
    one more time
    rear cog advise needed
    I got myself a fully rigid singlespeed a year ago thinking that I would give it a shot on the trails...
    Truth is I am clearly not hard (or fit) enough to pass up the full sus and hammer the trails on it.
    Anyway I still ride the bike semi regularly on the streets and the current gear ratio is just too low. Im running 32/16 and run out of gear pretty quickly on the flat roads here.
    So my question is what is the lowest cog I can go to on the rear?
    Cheers for any advice.
    B
    Bikes, beer and pizza.
    Reputation: ionsmuse's Avatar
    13 or 14.
    Why not a bigger ring? Usually about the same $$$, and it would improve drivetrain life loads.
    one more time
    Yeah good point - only issue is that I have a bashring which is only just covering the big ring.
    Need to check if a larger ring will fit without being exposed.
    Cheers for the advice.
    Out spokin'
    Dec 1999
    Quote Originally Posted by benzology
    If you're riding the bike on the street now you probably don't need a bash ring. For the cost of some BMX chainring bolts, you could lose it.
    --Sparty
    disciplesofdirt.org
    one more time
    Even better point sparticus.
    This forum is perfect for peabrains like me.
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    get a 39 front ring, ss bolts, and ditch the bashguard.
    "Knowledge is good." ~ Emil Faber
    one more time
    Cheers mono - actually i was expecting something more profound from you.
    Good advice.
    $5
    For 5 bucks you can get a 13 tooth cog. Why not see how that works before spending $30 on a chainring?
