Rear brake disc conversion - Surly 1x1 older model- Mtbr.com
Results 1 to 11 of 11
    ayeder
    Apr 2018
    First ever post, so please don't roast me for not having correct verbiage...
    I am currently putting together a single speed using an older Surly 1x1 frame. The fork is disc compatible, but the frame itself does not appear to be. I have been told that an adapter would allow the Avid BB7s I got to attach to the frame, and I have been told that the adapter is not worth it, will not work, and that I should just leave the rim brake on the back.
    For context, I live in Milwaukee and ride the trails around the city which are single track and mostly in the kettles. I imagine that an adapter would be functional for the level of riding I am doing, but would like other opinions.
    Here is the dropout on the bike - could you tell me what adapter I should buy? Or if I should not bother? Thanks!
    Oct 2013
    Dont bother. I have a later model 1x1 with the rear disc mount. I only upgraded to a rear disc back there maybe a year ago. It was front disc rear v forever. Id be worried about safety and reliability using an adapter. Mostly safety. Get yourself an old school brake booster and you will barely notice its v brakes back there.
    Reputation: Velobike's Avatar
    You'll find the value of the original 1x1s is climbing.
    You may be able to swap for one of those later ones...
    But consider using a drum brake.
    Latitude: 5736' Highlands, Scotland
    ayeder
    Apr 2018
    Why is their value climbing? Wouldn't you want bike frames with disc compatibility?
    Hardtail Steel Forever
    Reputation: jestep's Avatar
    I don't think you can adapt a horizontal dropout to disc without some serious modification. The caliper mount would have to move with the wheel since you'd be moving the rotor backwards when tensioning the chain. There's just no easy way to accomplish that if it's possible at all.
    WTB: Med Bontrager Ti Lite, PM Me...
    Reputation: dbhammercycle's Avatar
    I agree with the above posts, it isn't worth the trouble, and the drum brake suggestion may honestly be a good one. I agree with jestep that the correct way to do this is to take it to a local framebuilder who could attach the correct slotted disc brake mount to move the caliper into the correct position depending on the axle placement in the dropout. My MUSS and the newer Surly's have the that style of brake mount, look at pics to see how it should be done.
    That said, you may have a collector's item that someone may be willing to take off your hands so that you can purchase/trade for a newer disc version of the frame.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Quote Originally Posted by ayeder View Post
    There's a considerable Retro MTB movement. The smart guys are snapping up the old classics before the rest wake up to it.
    1x1s have quite a following.
    ayeder
    Apr 2018
    Any recommendations for a booster for this particular bike? I am running tubeless tires on it, so slightly wider than normal tire. Not sure if that matters with a booster.
    Reputation: J.B. Weld's Avatar
    If the seatstays are rigid enough you don't need a booster IMO, my Surly frame was very good with v-brakes. I'd try it without it and see how it works first.
    I brake for stinkbugs
    Wouldn't a brake booster make it worse. To me the biggest issue with V's compared to discs is the lack of modulation. But, I've never had any issue locking up a rear wheel at virtually any speed. Even a $5 set of Avid SD3's will dead stop a rear wheel without much problem.
    Quote Originally Posted by jestep View Post
    Some frames have such noodly seatstays that it's impossible to adjust a v (or cantilever) brake to be able to lock up. I've seen this mostly on older (real old) frames, most companies figured this out pretty quick and beefed them up appropriately.
  1. Replies: 8
    Last Post: 04-13-2017, 07:01 PM
  2. WTB Surly 1x1 frame 18", Surly Marges, Pugsley fork
    By smporter in forum Singlespeed
    Last Post: 06-08-2016, 11:44 AM
  3. Replies: 4
    Last Post: 04-11-2016, 05:16 AM
  4. Replies: 4
    Last Post: 10-29-2014, 05:47 PM
  5. Surly 1x1 w/ Rohloff and disc brake anybody?
    By brettsportler in forum Internal Gear Hubs
    Last Post: 06-18-2011, 08:38 AM
