RD (w/o modification at all) as a chain tensioner, it is possible ??- Mtbr.com
Results 1 to 5 of 5
    May 2010
    Im indra from Indonesia, I want to make a SS from my MTB frame with vertical dropout, but I dont have any budget to buy that Da bomb tensioner which is as expensive as Shimano Deore RD (I wonder why its possible ??), and I also dont want to breaking my old RD to convert it to chain tensioner
    my question is same as the title, is it possible to use my old RD without any modification to use it as a chain tensioner ????
    Jan 2009
    welcome indra!
    yes, it is possible to use the RD as your tensioner. just set the limit screws when you get it aligned with the cog/gear that you have and you are set.
    Reputation: davesauvageau's Avatar
    You can also install a small bit of cable with the "barrel" end in the barrel adjuster on the der if you have one and set the cable tension to hold it right where you want it.
    My motorcycle runs on infant blood
    Mtbr Forum Sponsor - Homebrewed Components
    Hi Indra, welcome. Both the ideas posted will work just fine. I would probably adjust the limit screws, but the cable is a neat idea as well.
    May 2010
    thanks for all the answers, I already try it and it works,
