Results 1 to 3 of 3
    Category Winner
    Reputation: teamdicky's Avatar
    Rake/geometry question
    I am thinking about swapping forks. Would I notice a 7mm longer axle to crown with a change in rake from 43 to 45? I run a Karate Monkey fork on my 26" Dean and I am incredibly happy with the way the bike feels. The new fork is lighter and ti (did I mention sexy?).
    WWW.TEAMDICKY.COM
    I get paid 3 every time I post on MTBR.
    Mar 2005
    I'll be changing soon also
    [QUOTE=teamdicky]I am thinking about swapping forks. Would I notice a 7mm longer axle to crown with a change in rake from 43 to 45? I run a Karate Monkey fork on my 26" Dean and I am incredibly happy with the way the bike feels. The new fork is lighter and ti (did I mention sexy?).[hear/QUOTE]
    I'm not really sure how much it will change the ride. I have heard that a change of 1"(25.4 MM) in axle to crown height will change your HT angle by about 1 degree. Since you are only changing 7mm I don't think it should be that big of a deal. Not sure what the difference in rake will change.
    I am putting together a 17" monocog aluminum and the Kona fork that will be going on it will be 420mm, compared to 435mm on my 19" steel monocog which it will be replacing. I still need to get some parts (avid brakes, seat post)and finish my 2 tone paint job , Dark gun metal gray metalic, and some other color to be determained, Yellow, blue, green, or white, not sure yet. I guess I will be steering a bit quicker w/ 15mm less axle to crown height. I'm changing to the 17" cause I want more standover and the aluminum frame was cheap and has disc mounts.
    fork change
    Doublt you'll notice the 7mm difference at all. It will make less than a .25 degree change in head angle etc. Kind of the difference between soft and fully inflated tires. Or the difference between runing a 2.1 and a 2.3 tire. Not a big deal.
    The 43 to 45mm rake change will quicken the steering just a tad. You may or may not notice it. It should be pretty subtle.
    You adapt within a ride and forget anything ever changed in no time.
  1. Replies: 154
    Last Post: 03-10-2005, 07:49 PM
  2. Replies: 4
    Last Post: 03-07-2005, 09:09 AM
  3. Replies: 0
    Last Post: 01-06-2005, 01:17 PM
  4. front suspension question
    By dan burnham in forum Beginner's Corner
    Last Post: 09-23-2004, 02:34 PM
