RaceFace No Longer Makes SS Specific Rings?- Mtbr.com
Results 1 to 23 of 23
    President of the Internet
    Reputation: Widgeontrail's Avatar
    Mar 2006
    I could not for the life of me find a Raceface SS ring chain ring to replace my current one. All the seem to make is NW ones now. NW is superfluous IMO for SS.
    I did find a non NW ring on eBay that I bought. Its says "Single" on it, but not single speed. It actually stamped 9,10 sp and is no way as burly as my old one. its 20 grams lighter. Too bad.
    Old & new ring below.
    Sometimes you eat the trail, sometimes the trail eats you.
    Thinking of buying a home?
    http://Search-Sacramento-Homes.com
    Downcountry AF
    Oct 2013
    nope, I tried looking for one last summer and came up empty. The good news is Absolute Black ovals are excellent for SS. I quickly forgot about my desire for a RF SS chainring.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    May 2005
    Why does it have to be Race Face? And what's wrong with running a narrow-wide chainring?
    There are still plenty of single speed options out there if you want a 104BCD by 32 teeth. Blackspire, for instance.
    Jul 2016
    I'll second AB. Oval rules. Wolftooth makes a spider / CR that's very nice too.
    Sent from my HTC 10 using Tapatalk
    Armature speller
    Sep 2004
    Narrow/wide FTW.
    Oct 2010
    Quote Originally Posted by NordieBoy View Post
    Narrow/wide FTW.
    just another "reason" to charge more for rings...
    WillWorkForTrail
    Jun 2012
    Quote Originally Posted by jmctav23 View Post
    Funny thing is, my first narrow/wide ring purchase was actually much cheaper than buying a replacement ring for the crankset I had at the time. Now 3 of the 5 mtb's in my garage have N/W rings on them and I'm happy to pay for them, because I've compared them to other rings, and frankly, there's not that much cost difference in it.
    Downcountry AF
    Oct 2013
    I agree there are alternatives. Blackspire, Surly stainless, Renthal? none of those come in blingy colors though.
    Edit: also Sugino, Dimension
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Feb 2014
    Blackspire mono veloce rings are great.
    That said, with the prevalence of narrow wide rings now, you can't be afraid of using them. People need to adapt.
    Mar 2006
    Quote Originally Posted by Shinkers View Post
    I have them on my geared bike. Seems pointless for SS. I wanted something stronger. I'll look into other brands next time around.
    ACC
    ACC is offline
    If you want strong get a stainless ring from Wolftooth. Elliptical rings are much better than round for singlespeed, as the power distribution is more even and there's less chance of spinning the rear tire when standing. Narrow wide is better even if unnecessary because the teeth wear better (aluminum) and they tend to push more grime out of the chain and keep things slightly cleaner. Embrace the now!
    Feb 2014
    Quote Originally Posted by Widgeontrail View Post
    They are indeed pointless for ss in my opinion. However since that's where the industry has gone, that's where the good stuff will be (strength, weight, quality, etc.) Since that's where manufacturers are investing their time.
    Oct 2013
    I just ordered up a Dimension 32t 104bcd dedicated single speed chainring from the local shop. We will see how it stands up. It sucks everything is N/W these days. I like the option of running a half link to slam the back wheel.
    Reputation: socal_jack's Avatar
    Dec 2008
    I use the Raceface N/Ws on mine, I think they wear better but I have this older Raceface 104/32t wierd thing is not completely anodized to the teeth. I was going to throw on ebay PM if you're interested for cheaps.
    Canfield Riot SS
    ROS9+ SS
    ROS9 SS
    GT Peace 9R SS
    Reputation: brent701's Avatar
    Sep 2012
    if it holds the chain on, who cares if it says SS or NW.
    I run AB on my SS
    Too Many .
    Feb 2005
    Pretty much. I used non-ramped SS rings when I started but now I just get NW and really haven't noticed a difference. I have the new Wolf Tooth oval ring and will try that next.
    [COLOR="Black"]HARDMTNBIKER on Instagram
    Seven Sola SLX ENVE MTN SS
    Sir9 Carbon Niner SS
    #1gearallyear #Iridemtn
    Reputation: LonelyDwarfProd.'s Avatar
    Jul 2015
    No experience with Race Face rings, but I've been super happy with the Chromag Clocker on both my single speed and 1x10 geared bikes. Chromag lists them as being for SS, and 1x10/11 applications. They're also reasonably inexpensive compared with other options out there.
    Chromag Clocker Chainring, 104 BCD > Components > Drivetrain > Chainrings | Jenson USA
    Jan 2009
    What's wrong with a NW ring? I have not had a "regular" SS ring on my bike for years. If anything, they are probably more likely to hold your chain in the event of your chain tesion loosening up.
    Chains made from all half-links SUCK but i can see the use of running a single half-link. Not a deal breaker for me though.
    Mar 2006
    Funny thing is, I swapped my chain ring because I put a new chain on and the drivetrain was grinding. I figured my aluminum chain ring would wear out before my steel Surly 17t cog. Not true. I put the new ring on and it was still grinding. So, I had to replace the cog too.
    It's pretty nice that you can replace your whole drivetrain for under $100.
    The Brutally Handsome
    Reputation: Sizzler's Avatar
    e*thirteen still makes standard SS rings like RaceFace, but I've moved to only using NW rings, which will hold your chain even if you loose tension or your chain is deflected for whatever reason.
    Reputation: economatic's Avatar
    Quote Originally Posted by brent701 View Post
    I run AB on my SS
    I 100% agree for SS. Maybe I'll put some fancy ring on the race bike for bling but the daily ride gets whatever is cheapest.
    Reputation: canonshooter's Avatar
    Are you still looking? I am sure I have a 32T blackspire single ring I could give you. Just pay shipping.
    Send me a PM if so. I can look in my parts bin after work.
    Reputation: dbhammercycle's Avatar
    I have a red RF ss 32T from a crankset for the wife's bike that now is 9spd triple, mounted but never a chain. Apparently I need to post it for.... 1 million dollars muuhaha!
    Seriously though, there are options out there even if you can't swap for same. I've used Surly and currently run an Oval. Nothing the matter with NW and there's really not enough difference in chainstay length to use a half link, at least for me and my preferred gearing.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
  1. Who's selling RaceFace Cinch Preload rings?
    By BJP in forum All Mountain
    Last Post: 09-29-2015, 03:21 PM
  2. Who makes SS specific hubs 142mm spacing?
    By robtre in forum Singlespeed
    Last Post: 07-24-2014, 11:53 AM
  3. Besides Raceface, who makes a 120mm crankset?
    By Fat Urkel in forum Fat bikes
    Last Post: 05-05-2014, 09:28 PM
  4. RaceFace Wide/Narrow Rings Availability
    By ALS650L in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2013, 08:10 PM
  5. Raceface Rings?
    By GrantB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-28-2012, 06:54 PM
