Results 1 to 10 of 10
    Reformed car junkie
    Sep 2004
    Quick BCD question
    I jsut picked up a set of Race Face Turbine cranks off ebay. They are the square taper veriety, and the seller says it is a compact crankset. They are comming with rings for a gearie, so I need to get a SS ring. SO, does any one know what the BCD on these cranks are so I can try to find a ring?!? Any help is GREATLY apprecieated. Thanks.
    blame me for missed rides
    Reputation: weather's Avatar
    compact means the BCD is 94mm for mid and outer rings..
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by weather
    ... assuming they are 5-bolt. I have seen the 4-bolt 104 mm BCD also called compact.
    mtbtires.com
    Steel and teeth.
    Reputation: b1umb0y's Avatar
    Feb 2005
    Quote Originally Posted by shiggy
    Did Race Face make a Turbine crank in the 4-arm configuration (with the square taper interface)?
    b1umb0y
    Reformed car junkie
    Sep 2004
    They are 5 bolt. I guess i should have specified that, but it was like 12:30 and I had a few brews in me, sorry.
    Awesome, thanks for the help. None of my searching turned up a definitive answer. Thanks again.
    Dec 1998
    Quote Originally Posted by b1umb0y
    b1umb0y
    I do not keep up on cranks that are made only in "short" lengths (180 mm and less).
    mtbtires.com
    Steel and teeth.
    Feb 2005
    Interesting... given the context of the original post.
    b1
    [QUOTE=SandmanLJS. They are comming with rings for a gearie, so I need to get a SS ring. QUOTE]
    Just use the ring that comes with the crank. Note: You will need to get shorter chainring bolts whether you get a new ring or not.
    "I've never been better .... nor cared less!"
    The man who fell to earth
    Reputation: Ziggy-Stardust's Avatar
    I have a set of 5 arm, Race Face Turbine square taper cranks - they have 110mm BCD.
    If yours are similar to mine, something like this should work:
    Available for $19 at https://aebike.com/site/page.cfm?PageID=30&SKU=CR3670
    Or just use the rings that come with it, they should work fine too.
    And don't forget the stubby single chainring bolts too.
    Good luck
    Quote Originally Posted by SandmanLJS
    Reformed car junkie
    Sep 2004
    I think im gonna have to wait and make sure they are infact compact, I really dont feel like wasting money I dont really have. Thanks guys.
  1. quick bar question
    By 94ranger234 in forum General Discussion
    Last Post: 04-13-2005, 10:04 AM
  2. Brought home new Kona....quick question
    By EvanPA2b in forum General Discussion
    Last Post: 03-21-2005, 10:07 PM
  3. quick flux question...
    By rexamillion in forum Turner
    Last Post: 02-04-2005, 01:52 PM
  4. quick kona coiler question
    By ajw8899 in forum Downhill - Freeride
    Last Post: 10-23-2004, 08:40 PM
  5. quick headset question (need help)
    By smoofers in forum General Discussion
    Last Post: 09-09-2004, 07:32 PM
