Question for you rennen rollenlager or soulcraft convert users- Mtbr.com
Results 1 to 2 of 2
    WNC Native
    Reputation: nitrousjunky's Avatar
    Okay you guys that use either one of these tensioners, How many teeth difference in cogs can you run with the same chain without it being too slack?
    Basically could I run the same chain and be able to change the tensioner position to run 20T or 22T cogs? 18T-22T??
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Reputation: Johnnydrz's Avatar
    Right now, my chain is almost tight as is (without tensioner) running 32x20. Changing to a 19t requires a fair amount of tensionning, with the Soulcraft Convert. I will probably try a 18t soon but I think I might have to remove 1/2 link...Not much play with a Soulcraft, it's too short to allow more than that. I had a DMR before, and that one had more leverage (arm length) to allow 2t difference.
    Johnnydrz
