Question! : What's the best tires for my Stumpy SS?- Mtbr.com
Results 1 to 5 of 5
    Let's Go!
    Reputation: Treadhead's Avatar
    I built this SS from my old 1994 Stumpjumper (see Picture) and I would like some opinions on what the best front and rear tire compinations would be for this type of conversion. Thanks.
    Reputation: shiggy's Avatar
    Dec 1998
    What were the best tires for it as a gearie?
    Has more to do with the terrain than the number of gears.
    mtbtires.com
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    Quote Originally Posted by shiggy
    Speed is another factor. The slower you go, the wider range of tires that will fit your needs well.
    Mr. P
    Let's Go!
    Well.. I guess my real question might be:
    Is it better to have a large tire in the front and a small tire int he back with low rolling resistance or high? I ride int he Pacific Northwest so wet conditions prevail int he winter but not neccessarily in the summer. Since it's winter now I wonder if skinny tires would be better to push through mud or not? Thanks.
    paintbucket
    Reputation: wooglin's Avatar
    IRC Mythos XC 2.1s front and back.
    Shiggy's point is that you should run the same tires you would normally run. I run Mythos XCs on my Stumpjumper for trail riding, so that's what I recommend.
    When the going gets weird its bedtime.
