Question for those with superior intellect......- Mtbr.com
Results 1 to 10 of 10
    What is the proper tool(s) selection to remove the chain ring from a set of ENO cranks?
    This perplexing question is inhibiting my ability to process work at my employment today.... hence the subject question is asked....
    My gratitude exceeds my ability to conveys words to the person(s) who provides worthwhile accurate information.....
    SS Jerry
    Reputation: ernesto_from_Wisconsin's Avatar
    using my mind...
    Quote Originally Posted by SS Jerry
    SS Jerry
    I have gathered cummulative data through proper market research...take it to a bike shop if you don't have the tool.
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    SS Jerry
    Lock ring tool. I already did it on my ENO. Doesn't take much effort. Just unscrew the ring (counterclockwise, natch) and you'll see the juicy goodness of the splines and chainring.
    https://aebike.com/site/page.cfm?PageID=30&SKU=TL2401
    SS Madness
    Reputation: xjohnnyx's Avatar
    No No No...
    My own extensive research and hands on training permits me to make the following erudition: A 3 lb. hammer and a #3 standard screwdriver should be all the equipment you need to fix any malady on any vehicle.
    juicy goodness
    Quote Originally Posted by Drevil
    That is the juicyest tool porn...I need to get me one of those. I will ride today...20 or so miles...being sick, having a new baby, it's taken a toll on my sanity. I have to ride...
    http://www.gottobeme.com/annabel.htm
    semi-evolved simian
    Reputation: Mine'sAPint's Avatar
    Quote Originally Posted by xjohnnyx
    And duct tape. You musn't forget the duct tape.
    yes it would...
    Quote Originally Posted by Mine'sAPint
    Keep in mind that some bubble gum, a crescent wrench, and a AAA map of western Montana might also do the trick.
    No relation
    Reputation: Ichabod's Avatar
    Too easy
    SS Jerry
    Round-trip one: The fastest pair, Adam and Larry, cross the footbridge, taking 2 minutes. Adam returns with the flashlight. Elapsed time: 3 minutes.
    Round-trip two: The slow pair, Edge and Bono, cross the footbridge, taking 10 minutes. Larry takes the flashlight and goes back across. Elapsed time: 12 minutes.
    Final trip: Adam and Larry cross, taking two minutes. Elapsed time: 17 minutes.
    Finally, the sniper in the tree fires...
    Don't you ever, don't you ever, stop being dandy showing me you're handsome.
    paintbucket
    Reputation: wooglin's Avatar
    DAyum. I haven't used a tool like that in years. But if its anyting like taking off the lock ring on an old school BB I'll happily pass. Between that and freewheels I might just consider giving up the whole SS movement entirely.....
    When the going gets weird its bedtime.
    Quote Originally Posted by wooglin
    Nahhh, it was really easy to take the lock ring off. However, I agree with you about freewheels and especially track cogs. Them Boone disc fixie cogs sure are easy to remove, and work well to boot!
  1. Brake response question? and Slider pressure question?
    By Gnar in forum Downhill - Freeride
    Last Post: 09-05-2004, 03:20 PM
  2. Chameleon setup question
    By FrontRanger in forum Santa Cruz
    Last Post: 04-28-2004, 02:07 PM
  3. Newbie lbs question
    By joshua_msu in forum General Discussion
    Last Post: 03-15-2004, 04:49 PM
  4. A couple of question...
    By bike_riot in forum Beginner's Corner
    Last Post: 03-14-2004, 06:48 PM
