Question for SS Converts- Mtbr.com
    I had been using a Paul Melvin on my SS conversion. I really liked the look of the Soulcraft Convert and the more direct chain path looked like it might be an improvement. My original Chainring / Cog combo did not allow me to run the Convert in the 'Pushing' mode and I had problems with loosing tension in the 'Pulling' mode. I have gone to a new Boone Ring/Cog combo and I invested in some half links. I could not get out to ride this past weekend after finally getting this thing together. What I wanted to know is how much slack in the chain is acceptable for a SS set-up? I know at least one answer will be "If it works, you're fine", but if I can lift the chain up in the middle a 1/2" or so, is that too loose? I've heard you don't want absolute tension, but wondering if I'm being too much of a slacker.
    MTBDad
    MCM #47.867
    "Freedom has a scent like the top of a newborn baby's head" - Bono
    Reputation: pacman's Avatar
    No it's not too loose (yet). Chain wear will soon make it too loose, depending on the number of cog teeth and the terrain you my bounce over. I manage to wear out (stretch?) chains rapidly - in hilly SoCal - so I can't see how anyone can use magic gears for more than 24 hours per chain. Any magic gear riders out there?
    Reputation: flipnidaho's Avatar
    That sounds about right...
    I have between 1/4 and 1/2" of slack on the SS...
    34N 118W
    Reputation: Hollywood's Avatar
    go to the disco
    you could always go with a Disco type setup for peace of mind
    http://www.offcamber.com/Product_Reviews/Discos.html
  1. Replies: 154
    Last Post: 03-10-2005, 07:49 PM
  2. Replies: 0
    Last Post: 01-06-2005, 01:17 PM
  3. Replies: 0
    Last Post: 01-06-2005, 08:44 AM
  4. front suspension question
    By dan burnham in forum Beginner's Corner
    Last Post: 09-23-2004, 02:34 PM
