Results 1 to 2 of 2
    Hairshirt Rider
    Reputation: Loudpawlz's Avatar
    Question - Paul dropout with axle keepers
    http://store.paulcomp.com/dropout.html
    Does one of the keepers need to be loosened to remove the rear wheel, or do you set the keepers and forget about 'em.
    R I D E S T E E L
    Reputation: one1spede's Avatar
    Aug 2005
    You need to loosen both to remove the wheel. I suppose you might be able to just do the drive side, would have to try it, but I always do both.
    At first, I only used the drive side tensioner, and it worked just fine. However, I like using both to center the wheel and such, then the skewer is just for extra security.
© Copyright 2018 VerticalScope Inc. All rights reserved.
