Question about paragon sliders- Mtbr.com
Results 1 to 7 of 7
    Waiting to exhale.
    Reputation: SMOKEY's Avatar
    How do you change a tire when running paragon tires? Does the wheel just drop out? do you have to adjust the tension screws?
    Quite possibly the slowest single speeder on earth.
    Now skating 'cause its cheaper.
    Reputation: J-RAD's Avatar
    Wheel just pops out because they are vertical dropouts!
    Waiting to exhale.
    ooops I meant paragon sliders being used as in single speed use, like the kind moots uses, and sycip. Do they still just pop out?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by SMOKEY
    And the answer is: "Wheel just pops out because they are vertical dropouts!"
    mtbtires.com
    Waiting to exhale.
    Thanks guys,
    So I guess once you adjust the tension and snug everything up, you just pop the wheel on and off?! Sweet.
    Aug 2005
    you should only have to adjust the sliders when you change either the cog or chain ring.
    Peace & Love
    Reputation: FoShizzle's Avatar
    Quote Originally Posted by lanceh
    or want to impress the chicks
