QRs & track ends- Mtbr.com
Results 1 to 46 of 46
    Bike Geek
    Reputation: slowlybutsurly's Avatar
    QRs & track ends
    I posted this in the Surly section but didn't get a reply. I'm trying my luck here...
    "I've heard of a lot of cases of skewers sliding in track ends & as a new KM owner, i'm worried about it happening to me. I'm currently using Sun Ringle Disc Jockeys with Salsa QR skewers. Anyone here using these? Any feedback? My 1st ride was in a technical man-made trail...0 problems but slipping is still at the back of my mind. I just want to have peace of mind & confidence in my equipment because it will make me a better rider."
    2 words: chain tug(s)
    I ordered some XT skewers per some of the suggestions on here. We'll see how they do.
    The only thing about tug nuts is they don't help on the non-drive side slip (from discs).
    Come see me after class
    Dec 2005
    i use 15-year-old Deore LX QRs on the back of my 26er and i've never had issues with slip. oddly enough, the thru-bolt on my 29er has to be cranked on big time to prevent slip.
    Reputation: djriddle's Avatar
    Shimano makes the absolute best MTB QRs. Use them and a properly adjusted tensioner on the drive side and you won't have any problems - might not even need the tensioner if you aren't very rough.
    BBI certified, 12+ years as mechanic
    Reputation: vindiggitydog's Avatar
    I was worried about the same problem with my Jabberwocky. I read up on sheldonbrown.com, the SS guru, and he states that as long as you use shimano xt skewers you will be fine. They work like a charm.
    Feb 2006
    yeah, not be the wet blanket here, but.........................
    I had track nuts slip on my FG cross bike.
    chaintug, and no issues.
    I have also heard of people throwing a left side one on to counteract the disk brake 'creep' that has also happened to some.
    so if steel nut (ie: Shimano) skewers don't do it for you, score a couple of 'tugnuts'.
    EricN
    The flood of fixed gear bikes, small t-shirts, and womens jeans will saturate craigslist
    Quote Originally Posted by mrsalty
    Correct me if I'm wrong, but isn't what you call disc brake "creep", mean that the wheel actually slips BACKWARDS, instead towards the front of the bike? In which case, the tugnut wouldn't help at all. I believe On-One tried to counter-act this by placing the disc mount between the seat and chain stays. I've heard it produced mediocre results.
    Reputation: boomn's Avatar
    Quote Originally Posted by p nut
    yes, i believe that is correct. I've never had a hint of slipping on the disc side on my Inbred, only mediocre part for me is that tool access to the caliper bolts is harder, plus having to use a >160mm rotor on BB7s for convenient setup
    Ovaries on the Outside
    Reputation: umarth's Avatar
    I don't have XT qr (shimano deore or something) and a chain tug and the only times I ever deal with chain tension is after I get a flat, which sometimes means a month or two of carefree riding.
    Scuffing the paint down to bare metal on the dropouts will help too.
    Reputation: ernesto_from_Wisconsin's Avatar
    You ride a Surly...
    You need Surly Tugnuts. You only need one. Two is overkill.
    See the little donuts there? it works with standard QR skewers. It prevents the skewer from moving forward. I use it on my off road Land Shark, and never looked back.
    Bike Geek
    I already have a Tuggnut on the drive side. I know that the Tuggnut on the drive side will help prevent forward slippage & rearward slippage is non-existent (correct me if i'm wrong) since the chain is pulling the cog forward...but what about forward & rearward slippage on the brake side? Should i put another Tuggnut on the brake side so the only thing i have to worry about is rearward slippage?
    Regarding quality of skewers, is there really a huge difference between Shimanos vs. other brands? the Salsas that i'm using are pretty tough...but i'm still worried.
    Quote Originally Posted by nordstern1
    it's not about quality but design. Internal cam skewers like Shimano can clamp down harder than an external cam skewer like Salsa.
    Here's another vote for Shimano XT Skewer. Got one on my Jabberwocky and not once have I had any slip issues.
    dgaddis - Did you sand down the paint in the dropout? Debating whether to do so on mine. If you did, any surface rust pop up after a while?
    I haven't sanded the paint off the track ends, and still no slippage.
    Good to know. Thanks, vindd.
    Bike Geek
    Ok, i'm gonna get some Shimano skewers. Thanks everyone!
    Bike Geek
    Any specific Shimano model? Would XTRs be the best or would Deores be good enough?
    XT is what i have been using. XTR might be overkill, but whatever boats your float.
    Nope, it won't happen. You're not pulling on the brake side. Just stopping, which won't affect anything, just saving you from hitting a tree.
    So another tensioner won't make sense there. I promise.
    Well, the disc brake forces will drive the wheel out the back of the dropout with the standard configuration. On one explains it well, which is why they mount their calipers between the stays. A decent XT skewer will be sufficient to hold the wheel on the place on the disc side. That's about all you can do. It works fine with my Pugsley.
    Quote Originally Posted by vindiggitydog
    The XTR has a ti rear skewer (used to at least) and the steel actually generates more clamping force. For disk brakes and especially on a SS the XT is the way to go.
    Framebuilder
    Reputation: Live Wire's Avatar
    Misaligned dropouts ( faces slightly out of plane with each other) will cause skewers and track nuts to clamp unevenly and then later slip. It's worth checking if this continues to be a problem.
    Bike Geek
    @Live Wire - It's not really a problem, yet, & i hope it won't be in the future. I was just warned by the LBS owner where i bought my KM that they had some KM owners that suffered from slippage. I also read some testimonials in some forums about this so i'm taking precautionary measures to prevent this. Thanks anyway for the advice, much appreciated.
    Reputation: davesauvageau's Avatar
    Might have good luck with something like this if used with tensioners!
    My motorcycle runs on infant blood
    Bike Geek
    Oh, yeah, i saw this somewhere! This is worth a shot! Thanks Dave!
    Jun 2010
    Quote Originally Posted by mijome07
    What tensioners are those?
    Reputation: farrisw1's Avatar
    These have worked great on my Surly 1x1
    No problem! Also, a little spendier option, you could do the DT Swiss RWS Skewers. They clamp extremely well!
    Quote Originally Posted by Fleetdog
    Redline @ $11 for the pair. They worked very well. I've since sold them and re-installed the stock tug.
    Feb 2006
    yeah, your reasoning is sound, as the slippage would go WITH the tug direction.
    I had thought that it had more to do with creating more surface area for the QR to clamp to the dropout. Maybe Not?
    so yes, overkill and probably NOT necessary.
    although it is nice to have the little screw to adjust tesion on both sides, and I do like the look of both intact.
    EricN
    Yes, you're right about the increased surface area of the tugnut possibly helping with keeping the wheel in place. Although, all of the tugnuts I've seen all have smooth surfaces...
    that's my reason for two tugs... wheel always goes back in the same place with no fuss. Plus I could see if there was any slipping because there would be a gap by the screw
    Feb 2006
    Quote Originally Posted by boomn
    yes, AND it looks BAD ASS
    EricN
    Reputation: Mighty Matt's Avatar
    skewers are taboo. get some bolt on hubs!
    Ride & Smile
    Jun 2010
    Has anyone tried the crank brothers skewers? I would guess if they really do give you more leverage to close them tighter (as the few reviews I've found online claim they actually do) that they would help prevent any slipping.
    Broke college student
    Dec 2009
    I ordered some of the Crank Brothers and they broke on me after about 5 times of clamping/un-clamping. They warrantied them and sent me another pair. I've put skewers on a million times, but thinking that maybe I was doing something wrong (since the Crank Brothers skewers are a little different design) I took them to my LBS to show me how to use them. They broke two days later just riding the trail. The clamp just popped and released tension on the wheel. Maybe I've just had bad luck with them, but I would seriously consider trying a different brand.
    PS - I used a2z Ti skewers that I got off ebay for $15 and they've been nothing but amazing for about a year now. I know they're not big name brand, but hell, they work!!
    I like beer.
    Bike Geek
    To those who suggested/are using XT skewers, i have a question for you guys. I just got a set of XT skewers from a seller in my local forum for around $20, brand new/unused. I'm kinda worried that the skewers i got aren't XTs because i compared them to my current XT skewers & they look identical aside from the markings. My XT skewers have "Shimano XT closed" printed on the levers while the ones that i recently bought have "Shimano closed" etched on the levers like on the 105 levers.
    The one that i have looks like this...
    The ones that i recently got, the markings look like these but the entire skewer looks like XTs...
    The seller said they came from an XT wheelset. Can anyone clear this out for me?
    I don't think they're XT's. Probably just Shimano Deore. Most of the XT wheelsets I've seen come with either Deore or lower end skewers. Also, all of my XT skewers have "XT" written on them--including a set from 1997 and 2008.
    Jun 2010
    What's the functional difference between the XT and other enclosed cam shimano skewers? I just got a wheelset that came with the second skewer pictured.
    Out spokin'
    Dec 1999
    Total speculation but I can't imagine there's any difference. It would probably cost Shimano more to have two separate production runs than to sell the Deore or LX skewer with the "lesser label" with identical spec at a lower price. Personally I've experienced excellent binding capabilities with every Shimano skewer I've ever used, and those simply look way too identical for me to believe there's any difference except the marketing factor (ie: label).
    Once again, this is pure conjecture on my part, tho.
    --Sparty
    disciplesofdirt.org
    Mine moved on hard landings and from using the rear brake hard until I serrated the fork surface a bit with dremel. Even with shimano skewers and a tuggnut on the drive side.
    Bike Geek
    thanks for the replies. guys! I'm actually ok with what i've bought, i just don't want to think i got duped by the seller. It really looks identical to my XTs, except for the markings.
    @p nut - I'm sure they're not Deores because those have different shaped levers & have holes on the end of levers.
    Yeah, I think they're pretty much all the same, anyway. Except for the weight?
    Quote Originally Posted by dakh
    Actually have to take that back, bugger moves still, just slower.
