QR Rohloff speedhub with surly 1x1?- Mtbr.com
Results 1 to 3 of 3
    Does any one know if a quick release Rohloff speedhub is safe to use with a surly 1x1 if tugs are used?
    Cheers
    Andy
    p.s if not, any other strong, steel ... cheap alternatives?
    Reputation: itsdoable's Avatar
    I have used a QR Rohloff hub on a horizontal wheel mount (Airborne Ti-Hag). I used an older Shimano all steel QR skewer, the ones designed for the old long slotted mounts. It held find without any tugs, although I did modify a no-name tug to fit a QR skewer just incase.
    This was with rim brakes, discs may cause slippage on the non-drive side if the caliper is located at 12:00.
    Cheers,
    Tom
    Reputation: Ventana OZ's Avatar
    Dec 2004
    I have used the 1x1 with a rohloff setup and Avid Juicy Discs. You must use the Tuggnuts or other alternative. It works fine but was a pain in the arse if I flatted etc. Better to get a bike with an EBB. It will work fine though.
  1. Rohloff Speedhub Questions: Chainline/Q-factor...
    By Ptor in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-14-2014, 08:34 PM
  2. Replies: 44
    Last Post: 07-19-2005, 10:47 AM
  3. Rohloff new internal hub availability?
    By EveryDaysANewDay in forum General Discussion
    Last Post: 06-13-2005, 08:40 PM
  4. In Defense of Speedhub: A letter to BIKE...
    By Speedub.Nate in forum General Discussion
    Last Post: 05-09-2005, 11:40 AM
  5. QR dual crown forks
    By rpl3000 in forum Downhill - Freeride
    Last Post: 06-25-2004, 08:20 AM
