Problem: pedaling not smooth- Mtbr.com
Results 1 to 27 of 27
    Could I have incompatible gearing? IS it the tension? Bad Hub? What's happening it it keeps wanting to jump on the chain causing loudness. Could it be a non compatible chain?
    Stokeless Asshat
    Reputation: jeff's Avatar
    Quote Originally Posted by digitalayon
    Chain line is usually the #1 problem with set up. Tell us what your running.
    Zip ties? Not on my bike!
    Want:
    650B rims or wheel set. 80's vintage 32 or 36 x 135mm
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Sounds like it is your feet.
    nothing to see here
    Reputation: Stevob's Avatar
    could be the rocks
    I see hills.
    I want to climb them.
    Out spokin'
    Dec 1999
    You were drunk when you wrote this, right?
    --Sparty
    disciplesofdirt.org
    Low Rep Count
    Reputation: 1SPD's Avatar
    Well, for me this spells upgrade! As mentioned in another thread, I would be telling my wife that I need a new crank and wheels due to the parts not working properly together. You need to get something with some King or Hope hubs and a new super light, SS specific crank set up!
    Seriously, check out your alignment! #1 culprit. But we need to know what your set up is to really help.
    Ihave a blackspire 36 tooth front chainring and a origin8 kit in the rear with tensioner my chainring is on the outerside of the crank.....is that my issue?
    horizontally compliant
    Reputation: Simpleton's Avatar
    If pedals not smooth then try sandpapering them. Start with 200 grits then graduate to 400 grits alternating with wet grits of 500 until going is smoothly. Coat with polyurethane until a light sheen is embarked upon.
    Stokeless Asshat
    Have you checked your chain line? 1/8" or 3/32" chain, ring or cog? Answer these questions, search this forum and you'll find the answer.
    Want:
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    Turn the barrel adjuster a couple turns or check your hanger
    Honestly... ahh I give up
    Quote Originally Posted by highdelll
    what barrel adjuster?....it's a ss
    I got the chain from a 1993 haro escape....could it be the wrong chain?
    Stokeless Asshat
    Quote Originally Posted by jeff
    Want:
    Stokeless Asshat
    Humor.
    Want:
    ~Disc~Golf~
    Stokeless Asshat
    Highdells honey rides a SS.
    Want:
    ~Disc~Golf~
    it's a man baby!
    one chain loop
    Reputation: fishcreek's Avatar
    recycling a 17y/o chain???
    everything sucks but my vacuum cleaner.
    Stokeless Asshat
    Don't be scared. It'll only hurt for a second.
    Want:
    one chain loop
    found an old rusty chain for a chainsaw, would that work??? its a chain..
    ok ok guys......found my issue......the teeth on origin 8 cog were too long....busted off a old on from a spare cassette and she's smooth as silk.
    Mtbr Forum Sponsor - Homebrewed Components
    lol....
    master blaster
    Reputation: veloreality's Avatar
    as i sip my jack and drink my beer...
    ~Disc~Golf~
    glad ya got it...
    tell me this though...what does it mean?
    It's all the way across the sky...
    It's FULL ON!!
    nothing to see here
    no way...like wow man
    I see hills.
    one chain loop
    hahahahahahahahahaha... i was waiting for you to say, i filed the teeth off and now its buttery smooth! seriously, the funniest thread ever!!! hahahahahahahaha
    It's FULL ON!!
    OH, OHHH, OHHHHHHHHH!!!!!! Double rainbow!!!!!!!
