Popping in drivetrain. Not typical symptoms... Any ideas?- Mtbr.com
Results 1 to 7 of 7
    Bro Mountainbiker
    Reputation: Sheepo5669's Avatar
    May 2010
    Whatsup guys,
    I have been getting this popping/ skipping noise/feel in my drivetrain for about a month.
    It happens when I go from coast --> power
    Chainline is perfect
    Chain tension is perfect. Its between 1/2 - 1 inch of play.
    Homebrewed components chainring. Hardly any signs of wear
    and homebrewed cog/ surly cog on my two sets of wheels both of which are built on Hope Pro II hubs. (no sign of wear on either)
    Chain doesnt have any bends or abnormalities and was not worn out when I checked it about week ago.
    Entire drivetrain is 3/32 width
    What do you think gives? You think the cold weather is affecting the grease in both my hubs?
    Anyone else had a weird and similar experience?
    Raised in a Chicken-Coop by Chickens
    Damn Fool
    You have two rear wheels right? Is is happening with both?
    Also, as a random guess, I've heard that the little springs that push the pawls out to engage the hub can fail on the Hope hubs. Have you checked those?
    It's not about being better than others, it's about getting the best out of myself.
    Bro Mountainbiker
    May 2010
    I believe I can recall it happening with both. Ill need to double check on that.
    I havent taken the hubs apart yet but they both are fairly new. 1 is 8 months old and the other is about one month old. I have been meaning to take em apart anyway to see how they work. It may resort to that.
    Another thing that came to me was frame flex. You think the sudden burst of power and forward momentum is slacking the chain and causing it to jump on/off the teeth of the cog?
    I weight 175 geared up riding a jabberwocky
    i don't think it could be frame flex.
    Reputation: jmmUT's Avatar
    Long shot but a bent or loose pedal will make a poppy type feeling sometimes, you may not feel it unless you are putting a lot of force on it
    What about loose chain ring bolts? Even if there semi tight they may shift under a load.
    one chain loop
    Reputation: fishcreek's Avatar
    i had similar experience before but mainly because of chain tension (too tight), my guess is the pawls and teeth are slipping on the initial load.
    check this thread, maybe we missed mentioning other possibilities.
    http://forums.mtbr.com/singlespeed/pop-646286.html
    everything sucks but my vacuum cleaner.
  1. Symptoms of low oil?
    By MillerSHO in forum Shocks and Suspension
    Last Post: 03-30-2019, 03:44 PM
  2. Drivetrain is popping?
    By Josh-L in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-13-2011, 05:53 PM
  3. What are the symptoms.....
    By ShoMyOFace in forum 29er Bikes
    Last Post: 07-24-2006, 06:55 AM
  4. X-5 Drivetrain Ideas
    By will8250 in forum Ventana
    Last Post: 03-05-2006, 08:31 AM
