View Poll Results: If given a choice how do you tend to adjust your bikes EBB?
Voters
36. This poll is closed
  • Above the 3 o’clock / 9 o’clock position for a higher BB
    19 52.78%
  • Below the 3 o’clock / 9 o’clock position for a lower BB
    7 19.44%
  • Never really thought about it, I just tension and ride.
    10 27.78%
Results 1 to 18 of 18
    Appalachian Singletrack'n
    Reputation: Endomaniac's Avatar
    New question here. A poll for all you EBB users
    A poll for all you EBB users,
    If given a choice how do you tend to adjust your bikes EBB:
    Above the 3 o'clock / 9 o'clock position for a higher BB
    Below the 3 o'clock / 9 o'clock position for a lower BB
    I have found that I can use different gear combos to get the same gear inches but one combination puts my ebb forward (longer effective chainstays) and another combination puts my EBB back (shorter effective chainstays). If given the choice I usually go with the rotated back (shorter effective chainstays) and up for a higher bb. I know differences are minute but when all you have is 1 gear drivetrain you have to fret over something.
    Last edited by Endomaniac; 05-26-2005 at 11:06 AM. Reason: to get rid of ’ instead of '
    Cold. Blue. Steel.
    Reputation: OneGearGuy's Avatar
    up higher...
    I tend to go up higher to have less chances for pedal strikes. I have heard this can be more of a problem on 29ers, esp when running longer cranks like the 180's I am using.
    I may try it in the lower position just to feel what the differences are in handling, etc.
    GG
    Spinning and Grinning...
    ali'i hua
    Reputation: SlowSSer's Avatar
    its definitely crossed my mind, to adjust the ebb to be higher to prevent pedal strikes or lower for some other reason. but thats about it- Im a "tension, forget about it, ride" type.
    as a side note, I was having issues with my old ebb and have had zero complaints with the newer type bushnell with the larger bolt. now, a happy user!
    King Pin
    Reputation: xrmattaz's Avatar
    Good job! Bushy!
    Hey Slow,
    Isn't the "new" Bushnell sweeeet? I'm loving mine over the older style, although just yesterday had to add a "beer can shim" to stop it from creaking. Rode a few hours today in total silence....!!
    It is a bit undersized on my Ti frame, as opposed to the older one, which fit very tightly.
    Quote Originally Posted by SlowSSer
    mudnthebloodnthebeer
    Reputation: quaffimodo's Avatar
    Quote Originally Posted by Endomaniac
    I'm also more concerned with fore and aft than up and down. I'm running pretty long cranks, so the aft quadrant works best for me.
    Out spokin'
    Dec 1999
    The poll is flawed
    Sorry to point this out but the poll is flawed, inasmuch as there is no reference point to establish standard BB height. Here's an example of what I mean: I run my EBB in the "below" position but since my Vulture's BB height is around 14", my "below" is significantly higher than many who run their's "above."
    --Sparty
    disciplesofdirt.org
    Should I add a disclaimer: 'This poll excludes the half dozed weirdoes in the world with 250mm crank arms and free-ride high bottom brackets"
    ali'i hua
    Quote Originally Posted by xrmattaz
    Hey Slow,
    to top it off, its on my sofa king! (we have rare frames, man!)
    i think you might have helped me discover my bottom bracket creak- its loud enough on my bike that a bell or chris king hub arent needed for noise.
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    EBB position
    I put mine as low as possible not for less pedal clearance, but to have as little seatpost exposed as possible. I bought a 17" frame because it had the right TT length, but the 350 mm seatpost has to be extended past the limit mark to give me enough leg extension. I need to order a 400 mm post, but have yet to do so.
    Out spokin'
    Dec 1999
    Oops, didn't mean to sound like I was comin' at ya by saying your poll is flawed, bro. Honest. Maybe I shoulda taken a different tack... like asking for a 4th poll option: "I'm a weirdo with a wacky frame and an abnormally large crank, therefore I'm exempt from this poll."
    Love ya!
    --Sparty
    disciplesofdirt.org
    ali'i hua
    (snip) I'm a weirdo with a wacky frame and an abnormally large crank....
    keep things like this to yourself- isnt this site PG-13?
    Out spokin'
    Dec 1999
    Guess I shoulda said "long" instead of "large."
    --Sparty
    P.S. See you in October, Ethan.
    disciplesofdirt.org
    King Pin
    Good job! aluminium
    A nicely greased 3"X2" or so section of beer can on the side opposite the bolt made mine absolutely silent! Slid right in there too....less tightening on the bolt as well.
    Two hour ride today, not a peep.
    ali'i hua
    hmm. will look into that. only because its still creaking and I know the isis spline and pedal threads are all greased nicely. maybe I'll check with a feeler gauge to see what can (double entendre?) fit in there.
    --Sparty
    Davey:
    yes- im sorry, but you will see me in october! inked on the callendar NOW!
    ps- is it bad if i'm already debating what ride to bring?
    Cracker-magnon
    Reputation: gpsser's Avatar
    Davey:
    Sweet, I have the work calendar inked in also... Hey Barbie, Ken's coming to see ya
    "Life is a F@#^ing story problem, get used to it - my son.
    Reputation: itsdoable's Avatar
    It depends on the BB-shell height, I have it up on 2 and down on one.
    ali'i hua
    Quote Originally Posted by gpsser
    nice! It'll be good to have some other californians join us. I think I was it last year.
    Reputation: bikeny's Avatar
    I origanaly ran mine in the lower position when running 175mm cranks, mainly for a lower center of gravity. But since I switched to 180mm cranks, I rotated to the upper position to reduce pedal strikes. I have also determined that ratcheting the cranks is a VERY useful skill on a singlespeed in rock gardens.
  1. My first fall
    By JRUSHE in forum Riding Passion and Stories
    Last Post: 05-23-2005, 05:08 PM
  2. Replies: 19
    Last Post: 03-28-2005, 09:03 AM
  3. Bushnell EBB Wedge Bolt Torque?
    By JimN in forum 29er Bikes
    Last Post: 02-15-2005, 04:08 PM
  4. Wheel Removal with EBB
    By hp14 in forum Singlespeed
    Last Post: 01-22-2005, 09:45 PM
  5. EBB help...
    By DSR in forum Singlespeed
    Last Post: 12-20-2004, 12:17 PM
