Phil Wood EBB- Mtbr.com
Results 1 to 5 of 5
Thread: Phil Wood EBB
    2006 sswc RockStar
    Phil Wood EBB
    can it be used any frame that is designed for an EBB, and do you have to use set screws with it?
    Brent
    Guest
    Quote Originally Posted by RockStarRacing
    The OD of the EBB itself is 2.137". It can be used with set screw or pinch bolt frames as long as they have an ID of about 2.140"
    Let me know if you have any other questions.
    Brent
    2006 sswc RockStar
    its to go in a rig, and a carver so no set screws, will it work and how much are they? (and what colours do they come in )
    velocipede technician
    Reputation: hollister's Avatar
    Quote Originally Posted by Brent
    how many licks to the center of a tootsie roll pop? but more importantly, you ever gonna do another pedal.........
    looking for 20-21" P team
    Brent
    Guest
    The rig is a wedge type so it will not work. I can't find any specs on the Carver so you'll have to take a look and see if it has set screws, pinch bolts, or nothing.
    Pricing here
    Black ano is $17 extra. Colors are by special order only and add about $45.
    Brent
