Paul's hub bearing replacement- Mtbr.com
Results 1 to 2 of 2
    The race, not the animal!
    Reputation: sea otter's Avatar
    I'm a bit of a shade tree mechanic, but I've never taken the bearings (cartridge) out of a wheel. My rear wheel for my SS has a Puals disk hub. I took out the axle due to the wheel sounding abnormal and found the drive side bearing to be in a nearly frozen position. The non-drive side spins like butter, but the drive side bearing is very rough to turn.
    Any one have "step by steps" on how to replace and what tools are needed?
    Thanks in advance.
    Do the one thing you think you cannot do. Fail at it. Try again. Do better the second time. The only people who never tumble are those who never mount a Single Speed!. This is your moment. Ride On !!!
    Reputation: shiggy's Avatar
    Dec 1998
    Gently tap out the bearing with a long screwdriver (work around the edges so it comes out straight).
    Clean up the hub shell.
    Press the new bearing in using a socket and a vice or hammer. go slow and be sure it goes in straight.
    I like to pack the bearing with extra grease before I install it.
    mtbtires.com
  1. Integrated BB bearing replacement
    By ren-man75 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-15-2004, 03:47 PM
  2. Cones inside hub worn out; where to get replacement?
    By dinger in forum Wheels and Tires
    Last Post: 09-04-2004, 09:14 PM
  3. replacement for rare 24h rear disc hub
    By Wynchestir in forum Wheels and Tires
    Last Post: 04-28-2004, 05:52 AM
  4. replacement hub parts for Pulstar?
    By MantisMan in forum Vintage, Retro, Classic
    Last Post: 04-19-2004, 11:13 PM
  5. Eggie bearing replacement.
    By happybiker in forum Weight Weenies
    Last Post: 02-22-2004, 09:48 PM
