Paul Hubs loosening- Mtbr.com
Results 1 to 5 of 5
    Reputation: Ilegal, Y Que?'s Avatar
    Apr 2005
    Paul Hubs loosening
    My Paul hubs will loosen during every ride and i have to adjust them back. Any solutions to this?
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    Quote Originally Posted by Ilegal, Y Que?
    blue loctite? what part is loosening?
    Reputation: MellowCat's Avatar
    I've...
    been having similar issues. I seem to have finally gotten them setup right. I went just a tad tighter than I thought would be ok. The wheels seem to spin perfectly and the bearing thrust plate seems to be staying tight now. I really don't understand the idea of adjustable cartidge bearings anyway!
    Combat Wombat
    Reputation: BrianU's Avatar
    I have had the same problem my last 2 rides.
    Quote Originally Posted by MellowCat
    I use a Paul hub on my front wheel and a couple rides ago it started to loosen up, I readjusted it when I got home but it loosened again. I will give your technique a try and see what happens.
    Brian
    Reputation: dRjOn's Avatar
    do you mean the bearing tension adjust?
    1) check the oring is in one piece (take the adjuster off and have a look see)
    2) de grease the oring or at least wipe it
    3) use minimum grease on the threaded section too (you *will* need to periodically check it is not seizing)
    that should do it. after i serviced mine a few years ago after a bearing change it did the same, but i had been a bit overzealous on the greasing...never slipped again.
  1. SC - are you listening? Scrap those DT Onyx hubs!
    By MTBmoose in forum Santa Cruz
    Last Post: 05-25-2005, 10:23 AM
  2. Universal or ISO disk hubs
    By godspeed in forum Brake Time
    Last Post: 01-22-2005, 07:39 PM
  3. XTR or XT disc hubs???
    By staind in forum Wheels and Tires
    Last Post: 11-29-2004, 06:11 PM
  4. Hope Hubs Disc vs. ONYX Hubs Disc
    By zaskar in forum Wheels and Tires
    Last Post: 06-25-2004, 10:05 AM
