Paul Disk Unit- Mtbr.com
Thread: Paul Disk Unit
    I fix choppers
    Reputation: HELLBELLY's Avatar
    New question here. Paul Disk Unit
    Has anyone had any experience with one of these? Is it possible to use the disk unit with another hub aside from the W.O.R.D. disc hub?
    Reputation: MellowCat's Avatar
    Email or Page..
    Shiggy, He runs one on his Matt Chester. His website is http://www.themudzone.com. His email address is on the site.
    Hope that helps,
    MC
    Quote Originally Posted by HELLBELLY
    I used one for about a year and it worked very well for me. Set up was a little tough to get it just right but once done it ran great. You have to use the pauls hub because it bolts on to the axel. If I can find mine I will sell it to you cheap. Hope this helps.
    Reputation: shiggy's Avatar
    Dec 1998
    My Disk Unit works very well. They are designed to be used only with a Paul WORD hub. It threads onto the axle in place of the end nut. The end is more than 12 mm in diameter.
    It would take a lot of work to get it to work with another hub.
    mtbtires.com
  1. Big kudos to Paul B!
    By Flyinturbo in forum Arizona
    Last Post: 04-22-2004, 10:07 AM
  2. XT disk brake weight
    By TeXe in forum Weight Weenies
    Last Post: 04-06-2004, 06:55 AM
  3. how should I straighten my 185mm disk?
    By banksgareth1 in forum General Discussion
    Last Post: 03-28-2004, 09:08 AM
  4. To disk or not to disk, that is the question.
    By pherret in forum General Discussion
    Last Post: 03-25-2004, 12:51 PM
  5. burner ready for canti & disk brakes?
    By oxygenrace in forum Turner
    Last Post: 03-04-2004, 08:41 PM
