Paul Components high flange flipflop 130mm -> 135mm- Mtbr.com
Results 1 to 5 of 5
    Hi there,
    I would like to convert a Paul high flange flipflop (fixed/free) from 130mm to 135mm. Does anyone know if this is possible? Is the axle kit for the Disk Word compatible? Any other tips are very welcome.
    thanks,
    david.
    anyone?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Call Paul Components and ask them . I am sure they would be more than happy to help you .
    Thanks, I'm waiting for a reply and was just seeing if someone has done this before.
    If it's a bolt-on just toss a 2 or 2.5mm spacer/nut per side.
    I've done it even with QR axles, on a QR hub you usually have about 5mm of protruding axle per side so you'd be halving that, axle still seats nicely.
    my paul's mtb hub uses brass tophat washers over a bolt that threads straight into the hub... dunno if yours is the same or not.
    If steel is real then aluminium is supercallafragiliniun!
