Paragon like sliders for a boost frame machined to fit 135 or 142- Mtbr.com
Results 1 to 5 of 5
    Ahhh the pain....
    Reputation: Raybum's Avatar
    Seems like an obvious thing right? Buy a new frame that has sliders but have a few wheelsets that are either 135 or 142. Seems like you could machine the sliders to have the necessary spacer features built in...
    Anyone seen anything like this available?
    I have 2 very nice and functional 135 (with a 10mm through DT Swiss) carbon wheelsets that I move between a couple bikes as needed and hate to ditch them or create wheelsets that are not interchangeable.
    Reputation: gonzo's Avatar
    alternative
    Quote Originally Posted by Raybum View Post
    You may want this ??? I have one
    Attached Thumbnails Attached Thumbnails Paragon like sliders for a boost frame machined to fit 135 or 142-paragonslotsthruaxle.jpg
    Ahhh the pain....
    explain Gonzo... where did you find it or did you have them made?
    Reputation: JoePAz's Avatar
    May 2012
    142 vs 148 rear is only 3mm per side so I bet you could make up sliders that would work in all combos. Heck since the brake are mounter to the slider I bet you would not even need rotor spacer
    148 wheels in "non boost" frames
    142 wheels in "boost" frames.
    135 wheels in "boost" frames too
    I already have sliders that fit my 135 wheels to my Verhauen non boost frame. Other off the shelf sliders fit 142.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '13 Santa Cruz Solo 27.5", XC, AM, blah blah blah.. I just ride.
    Feb 2010
    I wonder what would happen if you just let the rear triangle flex. Hell, we can use road 11spd freehubs on standard 135 spacing and those are nearly 2mm wider than a standard 135 spaced hub with 10spd freehub. 3mm might be pushing things a bit too far though.
  1. Are Lynskey sliders really Paragon sliders?
    By JeffL in forum Singlespeed
    Last Post: 08-05-2016, 05:44 AM
  2. Can Easton Haven 12 x 135/142 be converted to 10 x 135?
    By Spec10 in forum Wheels and Tires
    Last Post: 07-24-2016, 11:21 AM
  3. Paragon Rocker drops 135/142 insert exchange?
    By rpiontek in forum Frame Building
    Last Post: 04-04-2013, 11:18 PM
  4. Paragon Sliders in a Lynskey Frame
    By Ítzi in forum 29er Components
    Last Post: 07-29-2012, 01:43 PM
  5. Question: 142+ vs 135 to 142+ adapter
    By pedal-man in forum Wheels and Tires
    Last Post: 11-03-2011, 07:59 PM
