Oval 104 34t on Trek Superfly SS- Mtbr.com
Results 1 to 3 of 3
    Mar 2016
    Hi folks,
    Have recently had my SS love rekindled via a swobo mutineer I'm keen to build an XC style SS racer based around the trek superfly SS frameset.
    I'm up for trying an oval chainring like the black 34t, probably with XT cranks 104 BCD.
    Has anyone experience of fitting the oval ring, are standard chainring bolts sufficient to fit it to an XT ring?
    I assume I can get correct chain line by using a spacer kit as I hae done previously.
    Cheers for any insight,
    Rev
    Armature speller
    Sep 2004
    The 34t uses shorter bolts, unless you're running a bash guard.
    Reputation: Timon's Avatar
    I have a '12 Superfly SS, XT cranks and 34t oval ring.
    Works with normal bolts. But without spacing the chainring off the crank splines, the chain does rub on the splines just slightly because the chainring is so narrow on the squished sides of the oval. Eventually just wears itself through and works fine.
    Ridiculously fast bike.
  1. 2013 Trek Superfly vs 2014 Superfly...
    By Bryan1113 in forum 29er Bikes
    Last Post: 04-12-2016, 01:20 AM
  2. Replies: 4
    Last Post: 04-05-2015, 05:25 PM
  3. Replies: 3
    Last Post: 01-30-2015, 12:28 PM
  4. trek superfly 2013 vs superfly 6 2014
    By dansiwiec in forum 29er Bikes
    Last Post: 02-26-2014, 08:10 AM
  5. Replies: 0
    Last Post: 07-19-2011, 06:12 AM
