Outboard bearings w/EBB?- Mtbr.com
Results 1 to 5 of 5
    Category Winner
    Reputation: teamdicky's Avatar
    I was looking at the new Deus crank. Will it work with my pinch bolt EBB? Will it get in the way of the little hole used for adjustments?
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    Quote Originally Posted by teamdicky
    now THAT is a good question
    34N 118W
    Reputation: Hollywood's Avatar
    no prob
    can't really speak for RF, but the new XTR works fine with my pinchy ebb.
    WAWE
    Quote Originally Posted by Hollywood
    Someone else mentioned the XTR works on their expandy-EBB. The same tool is used for both Shimano and RaceFace cups... so with the same outer diameter, it should all work, in theory.
    http://www.parktool.com/tools/BBT_9.shtml
    The new BBT-9 Bottom Bracket Tool is designed to remove and install Shimano® Hollowtech II, Race Face® X-type, FSA® MegaExo, and Truvativ® Giga X-pipe bottom brackets. Laser cut for a precise fit, one end of the BBT-9 securely engages the 16 notches of the bottom bracket cups, while the other end engages the 8 internal splines of the crank arm adjustment cap.
    Lazy People Suck
    Reputation: Fett's Avatar
    I have a Phil Wood EBB and the new 960 outboard bearing XT cranks with the split BB shell and pinch bolts on my new ByStickel and it works just fine. No problems with clearance or adjustments at all. I would think the Race Face would work the same way.
    "Son, The world needs ditchdiggers, too"-Ted Knight, Caddyshack
  1. Spider bearings....any explanation?
    By jcospoco in forum Intense
    Last Post: 06-08-2004, 06:22 AM
  2. Titanium bearings?!?
    By Boj in forum Weight Weenies
    Last Post: 05-25-2004, 11:50 PM
  3. Has anyone ever replaced their bearings with ceramic ones?
    By jimjo in forum General Discussion
    Last Post: 04-16-2004, 06:15 AM
  4. Anyone with worn DU bearings?
    By Steve-O in forum Shocks and Suspension
    Last Post: 03-24-2004, 01:14 PM
  5. Tracer and Spider bearings size
    By pintense in forum Intense
    Last Post: 02-24-2004, 01:52 PM
