One piece Crank Bottom Bracket Question...- Mtbr.com
    New question here. One piece Crank Bottom Bracket Question...
    Hey everyone,
    I pulled an old bike frame out of the trash pile and am installing a new bottom bracket for the one piece crank. The goal is a single speed.
    here is the part:
    My question is this...what is the large washer at the bottom leftfor? Is it merely a spacer, and where does it go?
    I was told to install it how it came out of the box...but I can't remember how the washer was packed inside the box.
    all help is appreciated.
    I do not know, but you'll probably be able to figure it out when you try to install it.
    Why not just get an American to European converter and use a 3 piece?
    one chain loop
    Reputation: fishcreek's Avatar
    maybe it is a spacer between the bb and chainring. but i am certain the other is a locknut for the non-drive side.
    everything sucks but my vacuum cleaner.
    well i already did install it without using the washer...and it seems to work fine... lol
    but i'm just nervous knowing I had an extra part.
    I've thought about getting the conversion for 3 piece cranks...but this is an extremely low budget, so I"m keeping the one piece...if I get more into things I would probably end up going the 3 piece way...
