Is it ok to have a little slack in the chain?- Mtbr.com
    In the rear with the gear
    Reputation: RemfSS's Avatar
    I have sliding dropouts and the rear wheel is a bolt on and I was wondering after I have tightened up the bolt, I still have a little slack int he chain. Does that matter or should I not worry about that?
    Get some Cycle Snack!
    Iron Horse MKIII
    Q Ball 29er
    Fetish Fixed-ation 69er
    Musicologist: Live/studio
    Jan 2005
    I have ridden MONTHS with a worn chain. Still no skipping. Now when you get a new freewheel , then you ]have to buy a new chain. Does that help?
    FTM
    FTM is offline
    Reputation: FTM's Avatar
    Sep 2004
    You should have a little slack in the chain or you will cause excessive wear in your drivetrain (bearings and sprocket teeth). Just don't want so much that you would be in danger of your chain coming off while riding.
    That helps a bunch. I just picked up a 22t cog that I might switch out for the 20t that I am currently running, but I have extra chain links. Plus, this is a brandinew bike, so it hasn't seen much yet. Thanks.
    Iron Horse MKIII
    Q Ball 29er
