Offically on the back burner..OT- Mtbr.com
Results 1 to 1 of 1
    Retro Grouch
    Reputation: aka brad's Avatar
    Well it’s not like me to cut and run, but I finally realized that I wasn’t going to be able to use this crank. I received this Miche in a trade a while back. I particularly liked the crank because the paint was similar to some old Shimano “Look” style pedals I have. And it was 175mm, which I have had success with, but current don’t have a road set. The problem is the BCD; an obsolete Campy BCD of 116. The chainrings are pretty warn, especially the smaller 39T, which has two crushed teeth. I took a Dremel tool to it and it would have worked for a while, but at some point it needed to be replaced. I checked the usual places and found some bigger rings, but nothing sub 42T. If there was something more remarkable about the crankset I might stick with it, but for now it's looking like trading fodder.
    1G1G, Brad
    Just one more rep and I get the toaster!
