Odd numbered 104bcd front rings- Mtbr.com
Results 1 to 15 of 15
    Mar 2014
    Everywhere seems to just do the even n/w rings these days.
    Anyone know manufactures apart from renthal that still make resonably priced odd tooth rings.
    Im looking specifically for 33t.
    Ta
    Sent from my LG-H930 using Tapatalk
    No known cure
    Reputation: Vader's Avatar
    Renthal and e13 make 104/33T
    Ripping trails and tipping ales
    No known cure
    Double tap
    powered by peanut butter.
    Reputation: heartland's Avatar
    Endless Bikes makes a 104 BCD in a 33 tooth. Endless Bike Company | The Odd 1 Chainring
    It's not cheap, but you can get lotsa blingy colors, and Shanna, who owns Endless, is hella awesome.
    "Never trust a man in a blue trench coat. Never drive a car when you're dead." -- Tom Waits
    Reputation: dbhammercycle's Avatar
    Surly. I ran 33x15 on my MUSS back when it had 26er wheels.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Aug 2016
    Ta, I have an extra 33t 104 Surly in my parts bin. It's used, but has plenty of life left. Shoot me a PM if you're interested.
    Otherwise, I'd second the Endless Bike recommendation.
    Reputation: JoePAz's Avatar
    May 2012
    I have a 33t and 35t Singlespeed rings for 104BCD. My current SS use cinch cranks so they are of no use to me.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '13 Santa Cruz Solo 27.5", XC, AM, blah blah blah.. I just ride.
    Reputation: asphaltdude's Avatar
    Didn't On-One do a 33t ring, too?
    Reputation: Darth Lefty's Avatar
    Sep 2014
    Someday someone is going to come up with a front ring that will have 66 NW teeth and a 2-1 planetary gear so it can be both effectively 33t and NW at the same time
    No known cure
    Quote Originally Posted by asphaltdude View Post
    Probably. They have some oddball rings. They were the only current source for a 34/110 I could find.
    Aug 2016
    any benefit to odd over even? or is it simply a matter of finding the perfect ratio?
    Jan 2009
    ^it's a combination of finding the perfect gear ratio and what fits best on your bike. some combos will force you to move the axle in a sub-optimal position for your preferences, so finding the combo that allows you to put your axle in the right place to get the effective chainstay length you want might be needed.
    for example, I could run a 34/21 gear or a 32/20. I chose the 32/20 because it puts my axle further forward on my bike, shortening the chainstay length, which I prefer.
    to get an idea of the effective CSL you can get from different combos, check this out: http://eehouse.org/fixin/formfmu.php
    Mar 2014
    Quote Originally Posted by mack_turtle View Post
    Yea. This.
    For me it was finding the point that I could properly tension the chain with the axle where I wanted it. 34x20 wasnt right but neither was 32x20 so I went with 33x20. Yea I could have changed the rear cog to make it easier but I had a nice absolute black NW rear cog I wanted to use.
    Aug 2016
    Quote Originally Posted by Ross1200 View Post
    sounds expensive lol
    Mar 2014
    Quote Originally Posted by beerdles View Post
    It's not that bad actually. Really nicely made parts though.
    https://absoluteblack.cc/cogs.html
  1. Anyone using a 104BCD bash guard for a 2x crank with in-facing 104BCD tabs?
    By thefan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-18-2016, 12:28 PM
  2. SRAM X01 104BCD 11spd Chain Rings
    By bt100 in forum Cannondale
    Last Post: 12-05-2013, 03:26 PM
  3. Any big rings for 104bcd cranks?
    By AC/BC in forum Cyclocross
    Last Post: 09-08-2013, 10:02 AM
  4. Has anyone used a road triple on a mtb? Also, big steel rings, 104bcd?
    By car bone in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2013, 05:23 AM
  5. Fox 32 Float RL Fork, right side numbered indents??
    By armoredsaint in forum Shocks and Suspension
    Last Post: 08-29-2012, 04:45 AM
Members who have read this thread: 4
