NOOB single speed gearing selection question.- Mtbr.com
Results 1 to 5 of 5
    Reputation: 2FewDaysOnTrail's Avatar
    COGs are cheap but I thought I would ask you old SS Jedi for some advice.
    I've been riding my 29# geared 29er Rockhopper fixed in 32Front/21Rear For several rides to see if I am really ready for SS or if it's just my latest craze. I've been very disciplined in not using any shifting advantage and have walked a couple tough climbs that I have done in the past numerous times in 22/32. I've found almost no difference in my lap times on my favorite trail and I really enjoy the simplicity of SS. I am going to build one.
    My question is, if I build a 20# single speed should I stay with a 21 cog (3.2 ratio) or with the lighter bike and more efficient SS drivetrain should I just bite the bullet and go with an 18 cog (3.7 Ratio)?
    Salsa Bucksaw
    Trek Farley
    Niner Jet9 RDO
    Niner Air9 Carbon SS
    Rockhopper Comp SL
    Like you said, cogs are cheap. I've got 17-22T in
    my parts bin. I use 20T most of the time (33x20), though. Start with a 20 or 21, and go from there.
    Reputation: trumpus's Avatar
    Quote Originally Posted by p nut View Post
    Ditto - I'm a relative newb and grabbed 17T, 20T and a 21T (given to me by a friend). I've used the 17T when I had the bike setup as a beach cruiser to pull the kiddo in a trailer, but use the 20T on my local trails and think right now, anything smaller and I would struggle.
    Start with 20T and go down from there!
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    /\ This, expect to walk a few of the toughest climbs.
    Reputation: greasemonkeee's Avatar
    My advice is to pick up a couple cogs but start low and work up. I recently went to a higher gear and found I climb better since I'm not spinning and wearing myself on level ground. But that's mostly pavement riding. I haven't been on the trails really since then. And don't be ashamed to walk it. After a few weeks it gets easier but I still walk it quite often.
    If I want the luxury of shifting gears, I'll drive my car.
  1. Gearing up a single speed
    By bananakaos in forum 29er Bikes
    Last Post: 03-31-2011, 06:17 AM
  2. Replies: 5
    Last Post: 08-27-2010, 08:55 AM
  3. Single speed gearing question?
    By pmarshall in forum Singlespeed
    Last Post: 12-01-2007, 06:13 AM
  4. single speed pug gearing
    By messofzero in forum Surly
    Last Post: 11-26-2007, 08:11 PM
  5. Single speed gearing
    By jocko in forum 29er Bikes
    Last Post: 01-09-2006, 09:38 AM
