Noob question and recommendation- Mtbr.com
Results 1 to 7 of 7
    The 5th knuckle
    Reputation: jaycastlerock's Avatar
    I have an ancient Trek 9700 OCLV 3x8 that I would like to make a SS.
    I was looking at using this in the back
    Performance SS Conversion
    Of the ones I've found it has the most rings to fine tune the chain line.
    Up front, can I run the middle gear and skip getting a new crank set?
    Mar 2011
    yes i think a lot of guys use the middle ring , and the chain tension er and spacing rings look good to me .
    Reputation: Zakman's Avatar
    I used the performance ss conversion kit for a short while. It was easy to set up and worked fine for the 200 or so miles I put on the bike before I got rid of it (cracked head tube). I am sure there are better options out there but this is the only kit I have used. The cogs are narrow so they may dig into your free hub. When I got rid of the bike, I didn't bother to take it off. But like I said, it worked fine.
    Oh yeah. On the crankset I used; the middle ring and big ring were one piece. I ran the chain on the middle ring. I cut the teeth off the big ring with a mini hack saw and then got rid of the sharp edges and smoothed/evened things out with a hand file. I just left the little ring alone.
    Jan 2009
    i would recommend using that kit or something like it and getting a SS chainring. middle rings from triple cranksets tend to drop the chain.
    I have used a spring-loaded tensioner, then tried a DMR tensioner that is static and the static one worked a lot better.
    The 5th knuckle
    Thanks for the input. Appreciate it, I'll post it up when I'm done.
    Reputation: zorro's Avatar
    Feb 2007
    Hey Jay - I used Surly stuff along w/their singulator (in push up position) and have loved it. I'm on my old Trek 8000 hardtail 26", and am running 32x20 around green mtn mostly. I would get a 18 and 20 tooth rear for the front range stuff.
