Noisy ACS Claws- Mtbr.com
Results 1 to 9 of 9
Thread: Noisy ACS Claws
    Reputation: Legbacon's Avatar
    Noisy ACS Claws
    My ACS Claws freewheel makes a knock, knock, knock, knock sound when I pedal. If I coast a bit and then pedal I can find a quiet zone. What is going on here?
    Formerly Travis Bickle
    Team Robot. "modulation is code for “I suck at brake control.” Here’s a free tip: get better."
    at least i admit it
    Reputation: BiKeBaStArD's Avatar
    I have had the same problem with those. Personally, I think it is just cuz they are cheap. It sure would be nice to have a definate answer though.
    go outside and play
    Reputation: shiggy's Avatar
    Dec 1998
    That is the infamous "Claws Knock". I have yet to have one that does not develop it with use. It can be postponed if you soak the new FW in synthetic motor oil BEFORE you use it. Soaking a used FW will quiet it for a while.
    Do not know what causes the noise. Have not had one fail.
    mtbtires.com
    Thanks for the speedy replies.
    an eagle in your mind
    i have 2 claws -- 1 has that same knock... bad machining is what i was told
    anyways, i got a shimano mx30-- no noises at all.. quietttttttttttt
    Sofa King We Todd Did
    Reputation: SpinWheelz's Avatar
    Yeah, I have a Shimano freewheel and the pulley of my chain tensioner makes more noise than that freewheel.
    Me too
    Quote Originally Posted by SpinWheelz
    Thats funny I just put a Shimano on mine and had removed the ACS and the Shimano is very quiet, most people on this board said the ACS was a better freewheel but maybe not?
    AussieLostInNyc
    Reputation: gumby's Avatar
    For the extra few $$ take the shizmano
    Quote Originally Posted by vcyclist
    No way, as soon as I replaced my shizmano with a ACS I posted how unhappy I was that my nice silent KM now made noise when ever I coasted and sometimes when spinning.
    It's a shame, no chainslap and no noise was one of the beautiful things about SS.
    Now that I have settled on the 20t it's time to spring for the eno that gets the rave reviews.
    www.nycmtb.com
    .....spreading the love
    Brakes?
    Reputation: pimp-daddy's Avatar
    Knock Knock...
    I believe that knock may come from side-to-side play in the freewheel.
    Wiggle your freewheel side to side, and if there's much play, this may be your problem. You can take the play out by disassembling the freewheel (lots and lots of little bearings) and removing a shim. THere's usually 2 or more shims in there.
    It's a pain in the A$$, but if you're a gear-nerd, and you have beer on hand, you might even get some kind of wierd pleasure out of it.
    Or you could just spring $10 for a new one.
    Have fun.
  1. Replies: 13
    Last Post: 11-17-2004, 02:24 PM
  2. ACS 20T w/ Surly New Disc
    By NoDunut4U in forum Singlespeed
    Last Post: 10-21-2004, 07:36 PM
  3. ACS 20T w/ Surly New Disc (X-post)
    By NoDunut4U in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-21-2004, 12:49 PM
  4. ACS Claws - an important new finding!
    By Ron in forum Singlespeed
    Last Post: 08-12-2004, 01:54 PM
  5. 9spd chain on an ACS Claws freewheel... good idea?
    By jean-seb in forum Singlespeed
    Last Post: 03-01-2004, 07:40 AM
