Niner One9 has problem chain dropped- Mtbr.com
Results 1 to 9 of 9
    Hi All Expert,
    I have One9 SS (2008 model) about 2 months now chain drop more 4 times, The chain drops when I pedal fast and torque. Today I cracked hard because of the chain drop.
    Here is what setup
    1.Evolve Single Speed Crankset
    2.Surly SS cog
    3.SRAM PC-1 chain
    Please give input if anyone has experience for this frame.
    Thank you for your help in advanced
    H
    Reputation: stremf's Avatar
    Dec 2012
    How is the chainline? Don't eyeball it.
    http://forums.mtbr.com/singlespeed/c...th-738755.html
    Look to see if there are any signs of cracks, especially in the welds. Or bent chainring.
    Check your chainring make sure there are no bent teeth, and also check chain tension. But if you are pedaling when it happens sounds like bent chainring or bent teeth on chainring.
    Make sure none of your chainring bolts are missing.
    Hi All.
    Thank you for your help. I will check all of your recommendations.
    I just do quick check I think my chainline was off.
    Thank you
    H
    Reputation: Climber999's Avatar
    What's the condition of your chain? If it's over worn it tends to fall.
    It happened to me on my beloved Surly, using a PC-1 chain I had refused to replace.
    Quote Originally Posted by Climber999 View Post
    I have this chain PC-1 about two months. I need to check it.
    Thank you for your information.
    H
    Thank you for your link. I found out my chainline off a lot. It looks like working now.
    i have found a 1/8" chain sometimes will drop off a 3/32" ring even if everything is pretty close to perfect otherwise.
    i'd recommend buying the chain your front chainring is built for. probably 3/32"
